Are the icp and ipr in an obs 7.3 powerstroke the same as the ones in the superduty 7.3's or should I say are they interchangeable cun I use the ones from a superduty in my obs 7.3 PS?
Depending on the year of the OBS. The early ones take an IPR with what they call and edge filter, the late ones (96-97 ?) do not use the filter. I'm not sure on the ICP, but I think they are the same.
There was a guy on here a few years ago, that was having trouble with his oil breaking down after1500 miles or so. His problem was that he had an IPR with the filter in a truck that call for the non filtered one. After installing the correct IPR, his oil problem went away, so I'd have to say the filter does matter.
I'm running a 94.
With no edge filter. =)
The filter is a restriction into the IPR, thus creating more backpressure on the HPOP.
Thats probably why he was having a break down issue.
