1971 F100 Spring Tower
That's bad. I'd give a thorough survey and see where else is rotted. As it is there isn't a whole lot of meat there to bolt the new mount onto, and that rail has zero strength left.
To answer your question, I believe 65-72 was the same perch, then it changed in 73 to slightly taller with a longer spring. That may have been just the F100 4x4 that changed, though, some folks have said the 2wd perch stayed the same.
on
And it could be you'll end up having to replacing both sides.
Orich
on
I can help you out with a tower but you might need more than a tower. if your frame is only rusted where the tower was rivited to the frame rail i have that part still rivited on the tower. but i agree that you need to look it over real well after finding that rust through, have you looked where the cab is mounted to the frame, just curious also the other side might be about in the same condition,
on
MRCMAN58,
Thanks for the welcome. This is my first classic vehicle, and I really appreciate the wealth of knowledge that FTE's users are open to share. The other side looks good, and this is the only place I can see on the frame that developed deep rust. I ordered the '65 spring tower, and hopefully it will do the trick, but if not, I will contact you.
I'll try and post progress pics.
Spooky
11-18-2002 11:53 AM
