Bad gas mileage.
  #46
Old 01-17-2016, 07:38 PM
mic91F150's Avatar
mic91F150
mic91F150 is offline
mic91F150 is gaining momentum as a positive member of FTE.
Originally Posted by Gunnerboy View Post
And last fill up i got 140 miles for 11.8gals
I checked my 302 today...9.2 gals for 97 miles.close to 10 per gallon. what size engine is yours?
  #47
Old 01-17-2016, 07:51 PM
Gunnerboy
Gunnerboy is offline
Gunnerboy is starting off with a positive reputation.
Its a 302 with a 5spd
  #48
Old 01-17-2016, 08:05 PM
mic91F150's Avatar
mic91F150
thx I have AOD
  #49
Old 01-17-2016, 08:40 PM
Gunnerboy
Does it slow down and speed up as your MPH changes
No noise stays the same just went out and cruised in every gear and speed down my road...
  #50
Old 01-17-2016, 09:44 PM
ctubutis's Avatar
ctubutis
ctubutis is online now
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Are you sure it's not an HVAC blower motor on low speed? From where is this noise coming?
  #51
Old 01-17-2016, 09:47 PM
Gunnerboy
Not sure yet i never heard it before.. but then again now i am listening closely being i adjusted timing.
  #52
Old 01-18-2016, 01:04 PM
Gunnerboy
So took it for a speed racer like jaunt up the road for about 20 miles and it started knocking... checked the timing and it was at 20Deg BTDC... How does that happen!!? The distributor nut is as tight as it will go..
  #53
Old 01-18-2016, 08:09 PM
ctubutis's Avatar
ctubutis
A few possibilities come to mind:
- Sticking mechanical advance inside the distributor
- Sticking vacuum advance
But given that this is the 87-96 forum (I spend most of my time in 80-86, wonder how I got here), you likely have neither of those, yours will be computer-controlled; have you pulled your codes?
You should check your timing chain for excessive looseness while you're in this area.
  #54
Old 01-18-2016, 08:51 PM
Gunnerboy
Hmm well id expect the timing chain to be tight being it was replaced 30k miles ago and yes pulled codes.. says my airbag is bad and my egr is malfunctioning.
  #55
Old 01-18-2016, 09:02 PM
Nothing Special's Avatar
Nothing Special
Nothing Special is offline
Nothing Special is a name known to allNothing Special is a name known to allNothing Special is a name known to allNothing Special is a name known to allNothing Special is a name known to allNothing Special is a name known to all
Slipping harmonic balancer? Could it be that it's not the timing that changed, just the timing marks?
  #56
Old 01-18-2016, 09:16 PM
Gunnerboy
well it did start knocking all a sudden thats when i rechecked and seen it had changed.. i thought same thing.
  #57
Old 01-18-2016, 09:22 PM
ctubutis's Avatar
ctubutis
Are you checking the timing with the SPOUT connected? I hope not....
  #58
Old 01-18-2016, 09:36 PM
Gunnerboy
Nope! Learned about that here had it disconected both times... only variation is i used 2 differant timing lights.. So not sure if that would make any differance really. And i painted the numbers too in order to make sure that i was right. Had the engine warmed up also.
  #59
Old 01-19-2016, 09:54 AM
Mudsport96's Avatar
Mudsport96
Mudsport96 is offline
Mudsport96 is gaining momentum as a positive member of FTE.Mudsport96 is gaining momentum as a positive member of FTE.
Are you saying it has a knock, or like ping because its advanced too much?
  #60
Old 01-19-2016, 10:45 AM
Gunnerboy
It started making a knocking clicking like noise when i accelerated so i rechecked timing and it was at 20BTDC So i re adjusted to 12 BTDC Which no noise now and way more acceleration and horsepower... I figure ill check it again in 2 days make sure nothing moved.
redford
1999 to 2016 Super Duty
18
09-04-2017 07:52 AM
tnhogfan
2004 - 2008 F150
06-02-2017 01:15 PM
rogerranger2122
Ranger & B-Series
23
08-08-2016 06:24 PM
97-350
06-20-2016 03:41 PM
Jswars
2004 - 2008 F150
04-20-2016 09:48 PM
Quick Reply: Bad gas mileage.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
