292 Water pump and pulley
Hi Guys
I've got a F100 with a 292 in it, the problem is the pulleys of the engine and water pump don't line up.
My water pump pulley is about a quarter inch too far forward.
When I got my '54 F100 it was already changed from the 239 to a 292 Y-block.
I think the engine comes out of a 59 or 60 F100 (casting number B9AE, crossover exhaust pipe).
I bought a new pump from cardone but this one was the wrong size, too small a shaft and impeller.
What would I need to get things correct? What pump, what pulley?
Pump thats on it now has a hub height of 4 3/4" and 3/4" shaft.
Pulley is over 7" in diameter and has a depth of 2 7/16".
The pump I think I need is a cardone 55-234 but I'm not sure?
This would have a 3/4" shaft, 4.7" hub height but I don't know the impeller size.
In that case I would need a pulley which is around 2 3/4" deep.
Anyone have more info on this?
From the info I found online, it would be 4.7" hub height. This would put the pulley in the same position as it's now, 1/4" too far forward
Mounting flange seems to be tight on the shaft, don't want to use to much heat and destroy the seals.
I guess I'd better get some dimensions from cardone and go with the new pump first.
Mounting flange was in the same place so I put it in the press and put a socket over it and pushed it as far as possible.
Still is about 1/16 too far forward but I'm at the end and I think the belt will take it. Might wear easier but it won't do too many miles.
Thanks for the help guys!
1964FORDTUF
12-10-2017 04:12 PM
jawroper
05-31-2013 11:05 AM
mikescamping
07-08-2000 08:51 AM
