I am in the process of converting 2006 Lincoln (4.6) to 76 F100. I would like to Modify the existing Wiring harness, can unused inputs to the ECM just be removed ie removing the wire or does this need to be completed with software.
I have looked at the information that I have (wiring diagram 2006 Town Car) there is an input from evap canister vent to pcm I was not going to use this if the input was disconnected would the PCM care there is also a VSC looks like an output to air suspension trunk pull down would these items just not work but not cause any other issues. I can see that all the engine and trans controls need to be inputed to PCM. Do you know how the Pats system needs to be removed
Read something once about a guy using a Mark 8 engine and wiring into a Fairmont. It was on four eyed pride, seem to remember he had some problems with Pats and body control modules. Sorry can't find it now.
