PLEASE HELP! 2002 f250 7.3 won't start cold
Old 12-28-2015, 03:52 AM
dillon7.3
dillon7.3 is offline
dillon7.3 is starting off with a positive reputation.
I have an issue with my 7.3.... the truck will not start if it sits overnight without being plugged in, even in 65 degree weather. It starts and runs with a rough idle for about 10 seconds after its been plugged in for an hour, after the rough idle is gone it runs great .. it will Stat back up as long as the truck is warm (70+).... I've replaced the batteries, glow plugs, starter (it was going bad) and fuel filter. .. also replaced the gpr today. .... please help me out with ideas
Old 12-28-2015, 03:57 AM
Y2KW57's Avatar
Y2KW57
Y2KW57 is offline
Y2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputation
Ideas:
1. Try 5W-40 full synthetic oil in the crankcase
2. Try anti gelling additive in the fuel tank
Old 12-28-2015, 03:59 AM
dillon7.3
Thanks for the reply, it's 45 degrees here, I didn't think the waxes started to harden until 32 or below, it is definitely due for an oil change, I have about 7000 on this go.... I normally run Rotella t series 15-40
Old 12-28-2015, 05:01 AM
bielaf
bielaf is offline
bielaf is starting off with a positive reputation.
I had a bad problem with cold hard starts and I replaced everything as well glow plugs, gpr, fuel filter, everything I could think of and I felt with hard starts, leaving the truck plugged in. Till this year I switched to 5 w 40 full synthetic and boy was it a world of difference on cold starts. It starts right up and don't have romps any more wish I would have done it sooner
Old 12-28-2015, 05:25 AM
dillon7.3
I'll give it a try and let you know thank you
Old 12-28-2015, 08:12 AM
jhl3's Avatar
jhl3
jhl3 is offline
jhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to beholdjhl3 is a splendid one to behold
All good info. 5W40 will be your best friend. Rotella T6 is preferred by some on here, while others prefer Mobile 1 Turbo Diesel or Valvoline Premium Blue.
Check out:
Used Oil Analysis - Bob is the Oil Guy - Bob is the Oil Guy
for more info.
Old 12-28-2015, 02:59 PM
Colorado350's Avatar
Colorado350
Colorado350 is offline
Colorado350 has much to be proud ofColorado350 has much to be proud ofColorado350 has much to be proud ofColorado350 has much to be proud ofColorado350 has much to be proud ofColorado350 has much to be proud ofColorado350 has much to be proud ofColorado350 has much to be proud of
When you do the oil change add ARCHOIL 9100 ...full 16oz to the oil. I think I had a very bad case of stiction in the injectors so I ran some 10w30 Rotella with the Archoil for about 1000 miles then flushed it and the HPOP then changed to Rotella T6 5w/40 with another bottle of Archoil. It has completely changed my truck cold starts and how it idles/runs.
The truck started Saturday at 12* without being plugged in which was huge. I'm pretty sure I need injectors but this is helping.
The ar6200 included in the link will help the fuel side of the injectors. I also used their 6400D (cleaner) with the 6200... Can definitely tell there's a difference!!
Archoil AR9100 16oz and AR6200 8oz Kit! Perfromance Bundle! Powerstroke! Friction Modi... https://www.amazon.com/dp/B00WAK0QXE..._UbAGwbFG680S2
Hope this helps!
Old 12-28-2015, 04:13 PM
tonym17's Avatar
tonym17
tonym17 is offline
tonym17 is starting off with a positive reputation.
Hope this helps!
I ran it the full oil change.....cant wait for it to get cold to check....
Old 12-28-2015, 06:12 PM
HKusp's Avatar
HKusp
HKusp is offline
HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.
How long are you letting the glow plugs "do their thing"? If you are only using the WTS light, that isn't enough when it is cold out. Try letting them cycle for 45 seconds or so before engaging the starter.
Old 06-09-2016, 09:07 AM
Kenmc
Kenmc is offline
Kenmc is starting off with a positive reputation.
It not good to switch to a synthetic oil your seal's are set for normal oil run 10 w30 if anything
Did you test for power at the intake heater and glow plugs it could be the solenoid has gone bad
Old 06-09-2016, 10:34 PM
ExPACamper
ExPACamper is offline
ExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant futureExPACamper has a brilliant future
Hi Dillion7.3 and welcome to FTE!
Here's a thread where I went through a complete "test" to show the difference in the oils.
https://www.ford-trucks.com/forums/1...l#post16192687
Oh- and unless you are running a bypass filter, don't go past 5k on the oil. Your truck will hate you for it, LOL.
Good luck, you should notice an immediate difference with synthetic 5w-40w
Old 06-09-2016, 10:53 PM
Rikster-7700's Avatar
Rikster-7700
Rikster-7700 is offline
Rikster-7700 has a very good reputation on FTE.Rikster-7700 has a very good reputation on FTE.Rikster-7700 has a very good reputation on FTE.Rikster-7700 has a very good reputation on FTE.
I think this is not the case anymore with modern oils, if it ever were true to begin with. Plenty of people switch between synthetic and Dino all the time with no issues at.
Old 06-10-2016, 05:37 AM
HKusp's Avatar
HKusp
HKusp is offline
Someone dug up a thread from December....
Old 06-10-2016, 06:53 AM
ExPACamper
I fell for it...
Old 06-10-2016, 07:11 AM
Kenmc
Kenmc is offline
Ya I know I have seen a lot of people do this over the year's and lots of leakie rear main seal's
I tried it my self along time ago and I lots of leaks when I change back they all went away
Quick Reply: PLEASE HELP! 2002 f250 7.3 won't start cold
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
