2000 4.6 F-150 surging when heat is on
Hey guys, my truck has had a problem surging over the past couple weeks. It only does it when the heat is on. If I leave it in park to idle or stop at a stoplight with the heat on the rpms will jump about 500 rpms every 30 seconds or so. Turn the heater off and it doesn't do it at all. Any idea what could be causing this? It will stand the back end of the truck up in drive when it does surge like you're trying to power brake it. It seemed to develop after I sprayed the motor off at a car wash about a month ago. Maybe I got something wet I shouldn't have? I already changed the IAC valve thinking that was the problem but it wasn't. Any suggestions would be appreciated. Thanks!
several positions of the "heater" turn the air conditioner compressor on and use it to dehumidify the air coming into the cab. Let the truck set at idle in park and get out and look at the compressor when the RPM changes. The computer raises the motor RPM when the compressor starts........ see if this is related to your problem.
You have a wheel bearing that is going out. It allows the toner ring to fall out of alignment with the wheel speed sensor at low speed That causes the wheel speed sensor signal to drop out and the ABS unit does its thing.
Clasko 127
1997 - 2003 F150
04-22-2017 11:08 AM
dellwas
02-22-2009 02:13 PM
