Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
2011 f350 boost gauge problem and p0107
Old 12-27-2015, 10:30 AM
EaTmYtAiLpIpEs's Avatar
EaTmYtAiLpIpEs
EaTmYtAiLpIpEs is offline
EaTmYtAiLpIpEs is starting off with a positive reputation.
hey guys! I have a 2011 f350 with the 6.7 had it all deleted truck now has 165k on it. had 161k on it when deleted, after the delete the boost gauge doesn't work and stays at 35psi. also I have a p0107 code. I bought a brand new map sensor from ford. and still the same thing.
Old 12-27-2015, 02:11 PM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is offline
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
If you can call the company you bought the tuner from they may have been through this and can walk you through the fixes.
Old 04-25-2016, 01:45 PM
sherrijaaf's Avatar
sherrijaaf
sherrijaaf is offline
sherrijaaf is starting off with a positive reputation.
Were you able to get this figured out I'm having the same exact problem...went ahead and replaced the MAP and still getting same problem constant boost gauge stuck at 35psi...any help be greatly appreciated.
Old 04-25-2016, 02:51 PM
sherrijaaf's Avatar
sherrijaaf
Mine seems to reset or something and work after just a bit of runnin it turns on and turbo runs fine. Lost
Old 11-07-2018, 09:43 AM
ohmartm
ohmartm is offline
ohmartm is starting off with a positive reputation.
Same Problem
I'm having the same problem, anyone know what it is?
Old 11-08-2018, 05:20 AM
senix's Avatar
senix
senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
did anyone contact their tuner company as suggested? If it worked before tuning and now does not then it is something with the tuner or the tunes that were written. You will need to start with the person who provided them to you.
Alternately, if you take it back to stock does the turbo work correctly? If so then again, go to the tuner company it is there problem.
Old 05-28-2019, 08:08 AM
Jeff Keesler
Jeff Keesler is offline
Jeff Keesler is starting off with a positive reputation.
Has anyone figured out a solution to this issue?
Dale mckenzie
15
05-06-2019 04:53 AM
BigDaddyJanJan
10-18-2018 07:16 PM
b-grant
2017+ Super Duty
09-01-2017 05:45 PM
strokeithard
02-19-2017 05:49 AM
sherrijaaf
04-25-2016 10:16 AM
Quick Reply: 2011 f350 boost gauge problem and p0107
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
