67 F-100 radio - Page 2 - Ford Truck Enthusiasts Forums
67 F-100 radio
Old 12-30-2015, 03:22 AM
Frosty67
Frosty67 is offline
Frosty67 is starting off with a positive reputation.
The retro sound stereo has a 1.5" X 3.5" face if that helps. Wondering if like Red Mercury was saying, there would be enough to cut out of the 67 plate to make it work.
Old 12-30-2015, 10:02 AM
orich's Avatar
orich
orich is offline
orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.
I'd just get a later 68-72 adapter face plate that way you could always go back if you want to.
Orich
Old 12-30-2015, 11:52 AM
qman
qman is offline
qman is starting off with a positive reputation.
FWIW, I have a 68-72 push button radio if anyone is interested.
Old 12-30-2015, 12:29 PM
orich's Avatar
orich
orich is offline
You should post if it's a good working radio .RIGHT!!
Orich
Old 12-30-2015, 02:11 PM
67F100TX's Avatar
67F100TX
67F100TX is offline
67F100TX is starting off with a positive reputation.
I'm interrested in the radio
Please email me the info on the radio and the price... like to see pics if you can send them. My email is david @csacomics.com
Old 12-30-2015, 05:20 PM
qman
qman is offline
email sent.
Old 12-30-2015, 05:22 PM
qman
qman is offline
Orich
99.9% sure it works. It's been a while since I picked up two of them so I can't actually remember if I tested both. I think I did just can't remember. Mine is bolted in with the security bracket and all so there's no way I'm going in to try to test anything.
I also have one with no pushbuttons if anyone is interested in it. All 3 came out of F100s.
Old 12-30-2015, 06:08 PM
gangstakr's Avatar
gangstakr
gangstakr is offline
gangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud of
do you have it in your truck or would you like to sell it?
email sent
Old 01-06-2016, 11:47 AM
1972-34ton
1972-34ton is offline
1972-34ton is gaining momentum as a positive member of FTE.
Post Old radio electronics thoughts
Hooking up an old radio, that worked at one time, can fry it.
Here are some old radio electronics thoughts:
Electrolytic Capacitors (little cans) get old and dry out. Hot climates are worse. If the end is pushed out, that is a bad sign. If one pops or shorts out, it can do a lot of damage to the rest of the radio. These can be replaced with new ones, cheaply, or even solid types that will last. Maybe $10 in parts. A small, hot, soldering iron is needed, and a bit of practice first. Ask a HAM for help.
You might want to use the minimum fuse rating, in a fast-blow style for protection.
Further, you might want to add a "Transorb" across the feeds for some extra protection from surges. This cheap component will begin bleeding the excess volts across a zener diode and resistor to hold the input volts to a benign value. I think a 14v transorb would do it. They handle minute surges of very high voltages, but not sustained amps, like a fuse.
If there is interest, I'll dig out a part number. They are less than a buck. Put it just before the input to the radio 12v feed, and across the 12v/neg leads (like black/red).
Link:
https://en.wikipedia.org/wiki/Transi...pression_diode
Luck with yours.
Kevin
columbia1spring
10-25-2017 09:58 AM
Ryan Cooper
13
04-04-2017 10:25 AM
WB4IUY
03-01-2016 06:10 PM
vidaliaman
02-25-2016 09:18 PM
lil neet
16
01-21-2016 04:22 PM
Quick Reply: 67 F-100 radio
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
