CDR Valve Troubles and In Desperate need for info
On my 7.3, the piece I got from ford was a short piece of rubber tube with grommet attached. The CDR only had a short(1") piece of metal nipple on the bottom, which slid into that tube.
Not sure what yours looks like, but I bet you could modify your CDR to work with that piece, if you can find one at Ford.
If not, well, just make something and seal it really well with silicone. All you need to do is hold atmospheric pressure back; there's no real pressure in the crankcase.
My other question is, will this work to replace the factory one?
http://www.napaonline.com/Catalog/Ca...127_0374680678
on
Grommet for the intake pan is E3TZ-6A892-A
The tube is E8TZ-6A892-A
The CDR "adapter " is E3TZ-6A665-A
I am 95% sure this is correct. I just bought all parts a few months ago and still have the packages at home. Just not in front of me....
These may not look 100% like what you have. Do a Google search of part numbers to get picks. You will see that it should all work for you.
LARIAT 85
10-27-2017 11:59 AM
pinche002
19
02-07-2017 09:32 PM
XxWINxX94
18
07-01-2011 08:27 PM
