1 to 2 inch lift?
1 to 2 inch lift?
Originally posted by 380035
What's dangerous about a block on the front axle? They've been doing it on every other solid front axle vehicle for many years now.
when you say "they", who are you referring too? Other guys or the factory? I've heard of people welding in a cast iron block to the front spring perch then mounting their springs on top of it. I'd have to say that I'd put alot of faith in the welder.
an alternative is the Edge mini-spring kit other superduty owners have been using. i' don't know much about it since I have the old body style.
1 to 2 inch lift?
Originally posted by bcmmdl
Thanks for all the info. How much does that edge kit cost?
I think it's around $210-220. It is connected to the stock pack via a new, longer center pin.
Just FYI, I believe that putting blocks in the front is illegal in all states........
Hope this helps.
1 to 2 inch lift?
For reference:
In KY, there are no rules about how to lift or how much but the state troopers can use their discresion about what is "safe and reasonable". You could use blocks on the front but with the tremendous weight of the PSD why stress the stock springs more than necessary. I chose to assist these with an add-a-leaf kit and upgraded shocks.
My buddy with a 1993 F350 4x4 did have a front spring failure while hauling a load of cattle. The main leaf cracked over the axle.
Mustangking1
09-08-2013 03:02 PM
