It's a 96 and once I start my truck and drive it for 10-30 mins go into a store for about an hour, I'll go to start my truck again and sometimes it'll serg on start up, like start, die, start, die then run fine. It'll do it once I feel it fire up and let off the key. What's going on ?
It's a automatic, and huh yeah it could be that, but its so random and dosnt act the same as the last time I had a IPR go out, but I can see how it possible. And there's no codes showing up on the dash
If what you are describing is a romping start, try starting it in neutral. If it doesn't do it in neutral, then the range sensor on the side of the trans is probably bad.
Yes there we go thanks, its a romping start. And I just got done replacing that but its not OEM so maybe that's why it's acting up because I was getting a code for that a few weeks ago
All I did was bolt it on so I assume it's not. But I didn't see any oval shaped holes for adjustment but I could be wrong. And I tried starting it in neutral and same thing happened. It never Dos it on cold start ups
