Injector kit T
Old Dec 17, 2015 | 01:55 AM
Cjpower9185's Avatar
Cjpower9185
Injector kit T
Well I was quick testing my glow plugs with a test light, reached back to driver rest of block. Reached for glow plug and snapped,part of the t off for injector return line. Anyone know if auto parts stores carry them or does,it gotta be the whole,kit? I called stores n there derps n have no idea what I'm talking about. I love outside of tosn, don't wanna waste a trip if I ain't gotta.
Also I've been having an issue with my truck wanting to die when I make right turns, only right turns. I have,to pump,fast n it'll sputter but start running ok again. I have half a tank,
Old Dec 17, 2015 | 02:39 AM
Ford F834's Avatar
Ford F834
I have never seen the caps by themselves, only the kits. They might be available somewhere, but I would be surprised.
Old Dec 17, 2015 | 03:05 AM
Cjpower9185
Crud. You know if any way to ghetto rig it for a week or so.
Old Dec 17, 2015 | 03:56 AM
Ford F834's Avatar
Ford F834
If you got it clean enough you could try epoxy or JB weld. The return lines don't have any pressure to speak of, so as long as you are very gentle putting on the hose and hose clamp it should hold. Gob a little extra around the joint to give it some strength and be sure none squeezes inside where the O rings need to seat.
Old Dec 17, 2015 | 04:01 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Junkyard and or epoxy as mentioned above.
Old Dec 17, 2015 | 02:32 PM
tankguy's Avatar
tankguy
I have a few left over from my last change over. Thinking I may have both older and laters.
Old Dec 17, 2015 | 03:32 PM
mudmagnet63's Avatar
mudmagnet63
JB weld I put it all the way around the outside and kept it from the inside. still holding.
Old Dec 17, 2015 | 10:23 PM
Macrobb's Avatar
Macrobb
Ford dealers carry them, but they are somewhat expensive.
Old Dec 18, 2015 | 11:57 AM
The_Josh_Bear's Avatar
The_Josh_Bear
I did that once, no kidding on the price. Just one T costs $12. Half as much as a full kit.
I'd say JB like others as long as you get it really clean with acetone or something first.
Old Dec 18, 2015 | 12:56 PM
hturner12's Avatar
hturner12
Also I've been having an issue with my truck wanting to die when I make right turns, only right turns. I have,to pump,fast n it'll sputter but start running ok again. I have half a tank,[/QUOTE]
Sound like the pickup tube screens (cone of failure) fell off. Look in the stickies for information on them
hyghlndr
Apr 22, 2019 07:12 AM
brian42
20
Jun 15, 2017 02:29 PM
Diesel 724
13
May 25, 2015 06:29 PM
fhafer
Dec 18, 2010 10:58 PM
SMS888
Feb 11, 2010 11:14 AM
