New owner 1980 F100 Flare Side - Page 48 - Ford Truck Enthusiasts Forums
  #706
Old 03-15-2019, 11:12 PM
Oz Econoline
Oz Econoline is offline
Oz Econoline is starting off with a positive reputation.
Do you know how far from the body line the colour white will start.
  #707
Old 03-16-2019, 07:31 AM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
FuzzFace2 has a great reputation on FTE.FuzzFace2 has a great reputation on FTE.FuzzFace2 has a great reputation on FTE.FuzzFace2 has a great reputation on FTE.FuzzFace2 has a great reputation on FTE.FuzzFace2 has a great reputation on FTE.
Originally Posted by reamer View Post
Hi Dave
Don't do a single stage paint....
A scratch in single stage is, well, in the paint not an easy repair.
two stage, color then clear, the clear takes the beating, and you don't damage the color, (most of the time...)
Reamer
I already have 2 stages done, inside the cab and the inner fenders & fire wall does that count? LOL
If I had the time, you are painting the truck 2 times (4 base coats & 5 clear coats) and room as I am already painting it in stages then maybe 2 stage paint.
Plan is to paint the bed less fenders and tuck it away. When I paint the white I will do the fenders & cab, tape if off and then do the red.
As you can see to do 2 stage paint would be a LOT more work. Also if I wanted I could do clear over the bed (when together) and cab to protect the paint if I wanted to but I don't see that happing.
Originally Posted by Kramercd View Post
This is his beater go to the dump truck lol
A nice looking custom beater.
If it was to nice I would not want to drive or use it LOL
I will have to see when I get that far but if I do the paint thing the red / white will be on the body line with each line maybe in 1/8".
If I do the pin stripe tape it depends on what tape I use. 1 color (1/4" wide so it does not get lost / cant be seen?) I think would be just inside the body line
Multi line tape more than that and I would have to see on what looks good.
I should start looking for the tape stripes I like and buy them so I can figure what I think looks good so come paint time I will have a plan.
It all comes down to how much work I want to make for myself doing this.
Dave ----
  #708
Old 03-16-2019, 10:08 PM
FuzzFace2's Avatar
FuzzFace2
I got the light holes cut in the bumper.
Because the holes are in the part of the bumper them sweeps back the lights will need to be installed on an angle so they point straight ahead.
Because of this there would be a gap on 1 side and bottom you would see. It took a little time to come up with a filler. I am using 1" wide by maybe 1/8" flat stock I had laying around.
I could not bend it so had to cut the parts and will weld them to the bumper.
I need to buy some grinding stones or burs for my die grinder as I have some cleaning up to do before welding and after to make it look good.
Once the filler is installed I will work on the mounting for the lights.
I have taken pictures and when I get my site back up will post them.
Dave ----
vortec 1
1999 to 2016 Super Duty
536
11-28-2018 10:44 AM
FuzzFace2
11-19-2017 06:26 PM
FuzzFace2
25
11-17-2017 07:18 AM
Lightning23
35
01-26-2017 01:55 PM
07EXPYEL
06-07-2016 11:51 AM
Quick Reply: New owner 1980 F100 Flare Side
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
