Buying a '47 1/2 Ton
on
....I'd be taking a careful at the bottoms of those doors. That brown patch along the bottom could mean an after thought type fix. Which could mean poorly fixed rusty doors. Which could mean a bunch of work to fix/replace. I've seen patched up lower rust carefully concealed with a "nice" stripe of paint.
...And the running boards ... Wood??? Nice/decent/straight original running boards are very hard to come by for these trucks. Especially the 1/2 ton pickup. Obviously the owner couldn't find any...
Things to think on....
Stan. ...........
Stan. ...........
Did you get any pics showing the build process on your pickup? There has been more than one vehicle used in the build.
Since you are thinking of using Crager ss wheels I am thinking you are not completely satisfied with the look of the truck.
You are at a really good starting point if you want to change the look.
You can either go here:
Or here:
Or someplace in between. Right now you are leaning towards the former.
I don't think you are ready for Crager SS wheels yet. Maybe you could start with taking off the hubcaps.
If you are ready to take the leap we are here to help!
Or here:
Stan. ...........
Stan. ...........
I know this is nitpicking a darn nice truck but I've never been a fan of body colored bumpers. And the hood latch and trim in the same poo brown as the door bottoms is just wrong. Get on ebay and get chrome ones to match that nice chrome grill. I also vote stock hubcaps, maybe with wider rims and fatter tires on the back for just a bit of tire rake. The wood running boards....not horrible but would look a lot better with rounder edges.
Hmm, I'd have to see those running boards. What you can see don't look bad. My guess is the bottoms of the doors had some rust repair. The undercoating can kinda hide welds ect. Probably plenty solid now. With new door checks and rubbers around $9 a pair plus shipping, can't see re-using old crusty ones.
But hey, we can all find things and in reality, mine will never be that nice.
I also vote for reproduction of original hub caps, with trim rings. If that doesn't work for you any Ford passenger car hubcap made between 1940 and 1948 will go right on the original wheels.
That raises another question, does the truck have the original wheels? With the full wheel covers you may not have wheels with the original "innie" hubcap bumps.
#28
#30
