56 F-100 rear springs removal
On my 56 I would like to re-mount the rear axle under my rear springs. The PO tried to lower the truck and installed the axle above the springs. Due to clearance issues I want to change it back.
Looking at the front spring pins it looks like there is very little clearance between the front spring hanger and the inside wall of the truck's box. So it's looking to me like if I pound the front pins out, then they may not be enough room to allow them to slide out all the way. My question is then does the box have to come off to get the pins out?
Access to the backside of the pins is made by drilling a hole through the bracing for the bed support in line with the pin hole, which should be visible behind the bracket. Your truck bracket may already be drilled; mine wasn't, but it was no big deal. You place a large drift through this access hole and through the hole in the frame, against the pin, and pound the hell out of it. The pins will eventually come out. Make SURE that you remove the cross locking pin before attempting to drive out the spring pin!! The spring pin is grooved and the locking pin wedges into this groove to lock the spring pin in place.
fordf350camper
12-08-2012 04:50 PM
undertow91
07-06-2008 08:12 PM
TDS535
22
12-02-2006 09:10 AM
oscarxyz
20
11-21-2005 01:07 PM
