rear end gear ratio
#31
#32
#33
Here is my cam info: Grind number: FF 280H-10
Intake Exhaust
Gross valve lift .530 .530
Duration at
.006 Tappet lift 280 280
Valve timing open close
at .006 Int 34 BTDC66 ATDC
These specs are for cam installed at 106 Intake center line
Intake Exhaust
Duration at .50 230 230
Lobe lift .3063 3063
Rocker arm ratio .00 .00
Lobe separation 110.0
This is all I have got, does it tell you anything more?
Intake Exhaust
Duration at
Intake Exhaust
#34
#35
Something you may not have thought of. As you lower your cruising RPM to 2200 you will be operating with the converter for lack of a better word not "locked up". I know it's not a locking converter but operating at or below the stall speed means the converter will bypass a lot of fluid, this will hurt mileage and produce tons of heat, a sure way to kill a transmission. I have a friend that had a overdrive auto and a 2200 rpm stall converter. In top gear @ 65MPH he was turning 2000 rpm. He had a trans temp gauge and temperatures would soar. He called the Transmission manufacturer and they told him to manually shift out of OD whenever temps rose to raise RPM and stop the bypass of fluid lowering temps. Just my .02.
#36
#37
#38
Here's the description from Comp Cams...
"Designed for hot street/strip cars, these COMP Cams Magnum series cam and lifter kits require a higher compression ratio, rear-end gear ratio, and stall torque converter than stock. With a very aggressive profile, these cam and lifter kits provide maximum top-end performance for your high performance car."
Chances of that getting any fuel mpg are very slim. 110 LSA is a good clue of that. I'm sure it runs strong once you get into the power band though. I installed a few of COMP 268s in customers cars/trucks long ago, They were excellent street cams.
#40
I agree that a 460 with a conservative cam should be able to pull very "tall" gears. This is why Ford made the 2.47 gears in the 70s. However, his cam is not at all timed for low r.p.m. grunt. Tall gears and his engine would be a mis-match. You wouldn't get mileage or performance.
habfam
09-22-2004 05:04 PM
paulg
01-24-2001 06:23 PM
