Digital egt and boost gauge install
So it been awhile since I put any new parts on my truck. So I decided to get an actual boost gauge instead of useing my scan gauge. I have a digital egt gauge already.
this one here can also be set up for a boost gauge but it can only read one or the other. So I got a double one from the same company.
Along with the appropriate sensor.
So first took the black cluster bezel of a long with my scan gauge and mount.
Then I had to make the hole larger to fit the new gauge.
Then just had to wire it up.
Put everything back together.
After that I had to program it to read ferienhite instead of Celsius. And also had to set the parameters for the boost and to read in psi not bar.
And after a couple runs down the road I am pleased with my it. The reaction time seams a little slow but I may be able to fix that in the programming.
Thanks Darin.
Yeah it looks like it is supposed to be there Bob. The single gauge install was really strait forward. But on this one I had to set it up.
Ha your right Bill I have just been driving it. Sure did plan on getting it painted after winter but don't think that is gonna happen.
This is the gauge.
Automobile Multimeter, Dual Channel [SYL-2813] - $79.95 : auberins.com, Temperature control solutions for home and industry
This is the sensor
3 Bar, 48 PSI, Boost Sensor for Diesel Engine [AUBER-303] - $42.76 : auberins.com, Temperature control solutions for home and industry
And the egt sensor
EGT Probe, Exposed Tip [TC-KEGT] - $36.50 : auberins.com, Temperature control solutions for home and industry
This is the sensor
And the egt sensor
Gabe,
Where did you get the 12V power from? Did you tap into the existing gauge wiring? Or did you add a fuse and make a new circuit?
I already had my gauges ordered from Auberins before you posted this, so although I'd have a hard time proving it, I'm not totally copying you, just partly.
Thanks
Thanks
