"cleaning exhaust" speed up or slow down - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.4L Power Stroke Diesel
Reload this Page >
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 12-06-2015, 11:40 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
speakerfritz has a good reputation on FTE.speakerfritz has a good reputation on FTE.
so go the "cleaning exhaust" message while I was on the parkway....which made me wonder....since this system works off the exhaust back pressure sensor...should I speed up or slow down. some random thoughts
a.) if I speed up , more ambient air flows across the cooling system
b.) if I speed up , the engine generates more heat
c.) increase in engine rpm could increase the readings of the exhaust back pressure sensor
d.) if I slow down, engine produces less heat
e.) if I slow down, less ambient air flow to cool off engine
f.) if I slow down, less pressure in the exhause for the exhaust back pressure sensor to detect.
g.) going faster and running up the rpms while in "cleaning exhaust mode" will increase the effects of the exhaust flame out #7 and 8 are doing to burn off soot.....but that will also tax metal surfaces of turbo, number 1, 2, 3 temp sensors, exhust back pressure sensor, etc.
so whats best and why?
Old 12-06-2015, 01:12 PM
CrazySob's Avatar
CrazySob
CrazySob is offline
CrazySob is gaining momentum as a positive member of FTE.CrazySob is gaining momentum as a positive member of FTE.
Get on the freeway and drive...
Here is the deal, the filter pressure sensor and ebp sensor take info from maf and map as well. Speeding up increases fuel flow and boost, this means more heat in the dpf. It will speed the process up a little. And its a common misconception that there is "fire" out of cylinders 7 and 8... If you wants the egt sensors you will notice that around the dpf is where the heat gets trapped. The idea is not to increase heat in the motor, it is to get the fuel in as close to an atomized state as possible into the dpf. The dpf is what gets over 1k* and this is where soot gets burned off.
Here is what you as an owner need to know... When you see that message try and be on the freeway and let it finish. Having the motor under load while going through regen is the most efficient way of getting the job done. This also gives you a chance to let things cool as you get off the freeway and drive home.
You really don't need to over think the process... It is very simple and isn't an issue provided you let it finish. I always made a habit of down shifting and building boost to try and push any ash or what have you out of the dpf after regen, but this really isn't necessary.
Old 12-07-2015, 08:10 AM
JcF204's Avatar
JcF204
JcF204 is offline
JcF204 is starting off with a positive reputation.
Thanks for this. I wondered the same thing.
Brentburek
06-07-2018 02:46 PM
Hanger53
08-30-2017 01:42 PM
AGrayson84
07-20-2017 05:54 AM
Johnmd
28
01-16-2017 12:44 AM
Wealthk1
2017+ Super Duty
13
09-02-2016 05:16 PM
Quick Reply: "cleaning exhaust" speed up or slow down
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
