none starting/sparkplug problem
Old Dec 3, 2015 | 04:36 PM
RadioControlGuy85's Avatar
RadioControlGuy85
hey guys,
our 92 f150 5.0l wont start.it will try but wont fire off.
today we check the sparkplugs and there all very wet,they have spark coming off them but its a very bright white spark and its around the tip.its not arching off the tips its arching around the tip.
these are new spark plugs that havent seen any road time.so the question is what would cause this probblem? just bad sparkplugs or somthing else is going on?
Old Dec 3, 2015 | 06:07 PM
rla2005's Avatar
rla2005
What kind of plugs did you install? Standard copper core work best.
Old Dec 3, 2015 | 07:22 PM
RadioControlGuy85
autolights, they have no road time,just ran long enough to move around the drive way.
Old Dec 3, 2015 | 09:33 PM
wtroger's Avatar
wtroger
Pull the vacuum line off the FPR and see if it wet with gas. If it is the the FPR is bad and Is flooding the engine
Old Dec 4, 2015 | 07:21 AM
RadioControlGuy85
pull the line off the fuel pressure regulator and its dry after 5 mins of cranking the engine over
how long should i crank it over before it would show signs of wetness?
Old Dec 4, 2015 | 10:56 AM
timbersteel's Avatar
timbersteel
Was fuel coming out of the FPR vacuum nipple when you removed the vacuum line?
Did the engine fire while cranking it over after removing the vacuum line from the FPR?
Old Dec 4, 2015 | 07:39 PM
RadioControlGuy85
no the nipple was dry as was the vacuum nipple was dry.
no it just trys to light off but never dose.
Old Dec 4, 2015 | 09:21 PM
wtroger's Avatar
wtroger
Kinda sounds like it jumped time.
Old Dec 4, 2015 | 09:48 PM
zemus420's Avatar
zemus420
Originally Posted by RadioControlGuy85
hey guys,
when you turn to on position not starting it mind you. Do you hear the fuel pumps? If not check the fuses that are under the hood you may have one blown they are on the driver side near the brake booster if I remember correctly. Sounds like your not getting fuel.
Old Dec 4, 2015 | 11:26 PM
RadioControlGuy85
its getting fuel. it was throwing gas out of the cylinder when we was checking for spark and the pumps are working. it just up and starting doing this.out of the blue.
Old Dec 4, 2015 | 11:36 PM
wtroger's Avatar
wtroger
I had this happen on a Buick once. And it was the PCM turning on the injectors when ever it felt like it.
Old Dec 5, 2015 | 03:24 AM
RadioControlGuy85
really hope its not the pcm, every time we fix something on this truck somthing else pops up
Old Dec 5, 2015 | 12:53 PM
RadioControlGuy85
well got the thing to start but its missing like crazy, went to sit in the cap on the floor and i notice a little smoke, the floor was crazy hot and had done metaled my set belt covers, is this a sign that the cat is bad?
or what the hell is going on?
Old Dec 6, 2015 | 12:03 AM
zemus420's Avatar
zemus420
The floor got hot and melted the seat belt covers WTF??? I know the cats can get hot but I've never heard of something like this. Was this only happening on the passenger side of the truck. Go down and check for an exhaust leak near the area that got hot.
Old Dec 6, 2015 | 12:11 AM
RadioControlGuy85
we are thinking it was burning un burnt fuel in the cat,cause it was runing really rich. eye burning rich
