C6AZ-8509-G C6AE-8509-G Water Pump Pulley
Isn't there a book that cross-references part/engineering numbers that will confirm whether or not there are other parts, with different numbers, yet identical in appearance?
Had an issue where the pulleys; crankshaft, water, and P/S pulleys were not a match set and causing problems with belt alignment. Found I either replace the crank pulley to match the others, or the water pump pulley to obtain a match set; wow, what an improvement!!
C6AE-8509-E
Ok66 352 390 428 exc/PI Ford 53·55·60amp wo/TE
Ok66 428PI Ford std.(exc/AC) wo/TE before_14-feb-66
Ok67 390 428 exc/PI Ford 53·55·60 wo/TE
Ok67 390 Fairlane Std.(53·55·60amp wo/AC) w/AT and Imco
2 grooves
6.83" diameter
Ford Service Part Number ID C6AZ-8509-B
__________________________________________________ __________
C6AE-8509-G
Ok65 240 Ford w/AC
Ok66 240 Ford Integral/AC or wo/TE
Ok67 240 Ford Integral/AC-w_or_wo/TE
Ok67 240 Ford (42·53·55amp w/SuperXC), or_HangOn/AC w/TE
2 grooves
5.85" diameter
Ford Service Part Number ID C6AZ-8509-G
Ford Pulley:
Pulley
C6AE-8509-E
2 grooves
6.83" diameter
C6AE-8509-G
Ok65 240 Ford w/AC
2 grooves
5.85" diameter
Ford Pulley:
Pulley
kydavison
08-16-2020 03:47 AM
1985highboy
11-04-2017 11:55 AM
toolsmith
04-10-2010 09:35 AM
