Anything avail for Macbook?Or do I steal my boy's laptop?
Thanks
I just installed ForScan in WinD'ohs XP running under VirtualBox on my MacBook. I haven't tried connecting to the adapter yet, but I'll probably get to that tomorrow. I'll post my results.
I may have missed it, but will a wifi ELM327 adapter work with windows (laptop) if the the laptop has wifi?
Yes the wifi will work. Downloaded Forscan last Thursday and it it found my netbook with no problem. Still learning the in's and out's of the program but is fairly easy to use.
Thanks. Guess you are using a ELM327 or something similar ?
In a similar vein I never got FORScan to run on Linux with Wine. FORScan installs and is functional except unable to connect to ELM327 via bluetooth. FORScan on my android phone connects fine via BT with same ELM327, but android version has no CCT, Buzz test, etc. Just listens, can't talk like the PC version.
Yes the one I use is a X-series Wi-Fi ELM327. Can't remember where i got it but it also works with my Iphone and DashCommand.
OP has the ELM327 referenced in this thread at amazon for $10.00 IIRC. OP- Thanks for all the hours & easy step by step pics. This is what I need as I am pretty much illiterate with the tech stuff, I call it" Born too long ago". Reps to ya
As far as the $10 ELM327 goes, click here: [ELM327]
I have not seen that before Tugly, thanks for the info!! I could not find any reported issues with the VGate scanner that I am using which is why I selected it over the cheaper options when I was searching.
Reps sent!
Thanks for the info scoutcamper.
So tugly is there a elm327 you have found to work best? BAFX OR VGATE? Other.
I just ordered a Veepeak Wifi that was rated very good on Amazon. I read about 100 reviews last night so I thought I would give it a try. I plan to test with my iPad/iPhone, laptop and android. It was only $17 with prime free shipping with a no fee return or replacement. Could be a $17 lesson but I thought I would give it a try.
The BAFX is Bluetooth only, I believe. If the Veepeak is a flop, I may try the Vgate icar3 next.
Anyone getting blocked from downloaded the Windows version? I use Norton and it will not let me download the program. It says it is unsafe. I guess it would work if I disabled Norton...
