Potential Trouble, Need Help with buddy's truck
Hows it going guys, I am a normal over on the 6.7L Powerstroke forum. One of my good friends has a 2008 F-350 6.4 Powerstroke, Vermillion Red CCLB. When he got it, it had 110k with the emissions still on. The truck ran good as far as I could tell. So we deleted the DPF, but the tuner he bought, a Gearbox Z DPF-R first, then then Electron. He is saying that Gearbox told him that he couldn't delete the EGR. If anybody can tell me whats what, that would be awesome.
First thing that it's doing is when he turns the truck off, we hear a "whoof whoof whoof" that seems to be coming from the twin turbos. If this is normal then cool, if not then if anybody can point me in the right direction to guide him that would be great.
Second thing is when he is idling, on his Electron, it's changing from 4% load to 6%, his RPM changes +50, and starts almost "skipping".
Third thing is he is losing coolant from the little elbow in front of the Degas Bottle. We can see the residue from when it comes out of there, but we have never seen it actively coming from there.
Any help on any of the issues would be GREAT. The whole idling thing where it "skips" almost, you can hear it "miss" I guess you could put it as, and the coolant shooting from the small elbow in front of the degas bottle would be awesome. We gotta make it last a long time for him. Thanks fellas!
The leaking coolant is just that... Leaking coolant. You not seeing it can be attributed to the fact that these trucks hold pressure even after being shut off. The leak happens as the "hole" bleeds enough pressure to stop leaking. The fix is replace the fitting... I am struggling with the same problem on my horizontal egr cooler... For me its a matter of deleting because I am tired of dealing with the emissions on this truck. The bd egr delete kit is on its way...
Now... For the skip, thats a big problem. The first thing I want you to do is get the truck up to temp and pull the oil fill cap and set it in the hole. There WILL be blow by, every single 6.4 has had blow by from factory... The question is does that cap stay in the hole when set in place? If not, you have a cracked piston or sever ring wear. In that case your only option is to pull the motor and rebuild or replace. If it doesn't, that could be a bad injector. I would expect to have a code (and a CEL) with this. There also may be another underlying factor as well. Any time you have a "skip" on a 6.4 you NEED to get it into a shop. These trucks are really good at hiding problems. Once a dead skip or misfire is identified its usually a major issue.
Let us know what you find with the blow by test, remember you still see vapor. Its what happens when you set the cap in the hole and let go that we need to hear about. After that we can tell you what you need to do.
Just an update, he is just going to take his truck to a dealer for a Diagnostic at some point. He took a video and we could see a fair amount of blowby, but it wasn't enough to "shoot" the cap off. Injector might be, but like it was stated earlier I would think there would be a check engine light.
The pcm must see 5k psi to fire and idle.
I would be curious on what the fuel pressure is, not just the high pressure system. They will throw an IDS on it and run various tests, but I almost wonder if your hfcm is taking a crap. If they can't find anything have them run a pressure test off of the lift pump (hfcm). If it isn't pushing volume to the hpfp you will start to see problems. Generally I would expect to see issues while driving more than at idle though.
The other question is, does it smooth out once its warm? If the oil fill cap isn't blowing out of the fill hole you don't have a cracked piston or a MAJOR compression issue. Could still have worn rings, that isn't uncommon on stock trucks. You could very well have an injector that isn't firing properly as well. They will do an injector balance test and it will give an idea of injector health.
If they do a relative compression test don't let them tell you the motor is blown though... It is a common Ford tactic to run a relative compression test and try to say you have a dead (or multiple) hole. Relative compression tests are not accurate on a 6.4, they must test each hole...
I really don't think you have a base engine problem (crazier things do happen with these trucks though...), but without access to the truck its all just speculation as far as diagnosis. Let us know what they find.
It doesn't do this skippy crap all the time. Most of the time it'll do it but it doesn't matter if it's hot cold warm nothin. If I pull over and put it in park and sit there it'll usually do it for a little bit. I give it a little throttle and it'll calm down. It's also not like it's struggling to stay running either. It honestly sounds like it's gotta a bigger can in it and it's loping. It shakes the whole truck. I've never had a problem while driving though. I really don't understand it.
