56' racecar themed F-100
#122
One side I had to bend the curvature of the hinge to bring the door in, I also had to tweak the frames to lign up, passenger side I had to cut the back of the cab along the door Seam and put in 1/4 filler to close the gap,if you remove the drip rail like I did,you'll find another headache!
#123
#124
I like the drip rails. They are part of the trucks character. When you start shaving too much off these trucks they just don't look as good. But this is just my opinion, which doesn't mean much.
#125
Received 4,132 Likes
on
#126
#127
Just wondering what I should do with the drivers side. See pictures. Should I edit the A pillar to match the door? Other than bending the door out to it.
Drivers side (cant live with this)
Passenger side (can live with this)
#128
on
#129
#130
The A pillar has a flare just in front of the door edge...it's supposed to stick out. The rationale for this is that the flare deflects the wind away from the door seam as you drive down the road. If you pull the edge of the door out to meet the outer edge of this flare then you have defeated the purpose of the design...results in more wind noise and possibly poor weatherstrip sealing in that area.
#131
#133
Are you planning on building your own frame? If so you might want to read through this thread:
Chassis Building 101. Ride Height
Gustave
Gustave
#134
Gustave
Gustave
Upper control arm mounts will be adjustable, up and down, side to side as well as trailing arms etc
I'm going to get the chassis at a basic ride height I want so I have some adjustment up and down if needed though.
