56' racecar themed F-100
  #76
Old 01-07-2016, 06:15 PM
56panelford's Avatar
56panelford
56panelford is online now
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
Originally Posted by Björn View Post
were do they go have them here but dont know were to place them
Those pieces used for the arms of the robot go on the end of the lock tumbler and insert into the lever to lock the doors, I don't have a picture at the moment but can take one tomorrow as I will be dismantling the hardware on my doors in preparation for high build primer. Unless someone else posts a pic before me.
  #77
Old 01-08-2016, 01:38 PM
56panelford
Posting Legend
For Bjorn...
  #78
Old 01-08-2016, 03:57 PM
Björn's Avatar
Björn
Björn is offline
Björn has a great reputation on FTE.Björn has a great reputation on FTE.Björn has a great reputation on FTE.Björn has a great reputation on FTE.Björn has a great reputation on FTE.
thanks so the one I got in the package from altman latches are the same
  #79
Old 01-16-2016, 06:50 PM
chad77's Avatar
chad77
chad77 is offline
chad77 is gaining momentum as a positive member of FTE.chad77 is gaining momentum as a positive member of FTE.
Few more hours and I might have it done. Once the console is done. Back on the rotisserie I think
  #80
Old 01-20-2016, 08:25 PM
chad77's Avatar
chad77
chad77 is offline
Has anyone ever modified the pedal area to make more leg room?
  #81
Old 01-20-2016, 08:38 PM
Dr G's Avatar
Dr G
Dr G is offline
Dr G is gaining momentum as a positive member of FTE.Dr G is gaining momentum as a positive member of FTE.
Yep.
  #82
Old 01-20-2016, 08:46 PM
chad77's Avatar
chad77
chad77 is offline
Originally Posted by Dr G View Post
Yep.
Nice. Ya I am thinking I may need to do this. Hate to try and do it when it's done.
Thanks
  #83
Old 01-23-2016, 10:40 AM
chad77's Avatar
chad77
chad77 is offline
Made some seat rails from 2x3 and tacked in place.
Mounted driver seat.
  #84
Old 01-23-2016, 07:17 PM
chad77's Avatar
chad77
chad77 is offline
Mocking up the pedals
  #85
Old 01-31-2016, 12:18 PM
chad77's Avatar
chad77
chad77 is offline
Back on the rotisserie to seal up underneath. <br/><br/>Im going to have it sprayed underneath with a linex type product. Was just wondering if anyone else has done the same and if so, did you do it before any body paint was done or after?
  #86
Old 01-31-2016, 12:27 PM
56panelford
Posting Legend
I did Chad, I used the EZ liner purchased at Canadian Tire, did the same to the panel truck.
  #87
Old 01-31-2016, 12:51 PM
chad77's Avatar
chad77
chad77 is offline
So you did that before final paint right? When you get to the paint part. Do you sand some of the liner down and overlap the paint on it a bit?
  #88
Old 01-31-2016, 12:57 PM
56panelford
Posting Legend
I still need to spray my high build primer and will mask off the bed liner so the paint will just overlap it about 1/4" or so. Will give it a bit of a scuff with 220 before the high build then go on from there.
  #89
Old 01-31-2016, 01:39 PM
chad77's Avatar
chad77
chad77 is offline
Ok I think I might go that route as well. With the ez liner instead of linex. Be easier I think
  #90
Old 01-31-2016, 01:44 PM
56panelford
Posting Legend
Linex is good stuff but don't think you could do it yourself , would have to take it to them, it's sprayed on hot.
Quick Reply: 56' racecar themed F-100
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
