56' racecar themed F-100 - Page 29 - Ford Truck Enthusiasts Forums
  #421
Old 03-14-2018, 06:50 PM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
bjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant futurebjmayberry2 has a brilliant future
Keep us informed on how it hooks up, works, any extras you needed to buy.
  #422
Old 03-14-2018, 06:54 PM
chad77's Avatar
chad77
chad77 is offline
chad77 is gaining momentum as a positive member of FTE.chad77 is gaining momentum as a positive member of FTE.
Will do. It was told the little tank option you can get so you can use your mechanical fuel pump is not a good way to go. The in tank retrofit fit kit is your best option and cheaper. Both require a return line to the fuel cell.
I'll try and do detailed pictures etc. Just not sure if I will get to it this weekend or not.
Heard good things about this setup. Was just told not to use the timing control unless you know 100% what you are doing.
  #423
Old 03-16-2018, 11:10 PM
chad77's Avatar
chad77
chad77 is offline
Started installing the FiTech system tonight. It's actually really simple. More pics tomorrow.
  #424
Old 03-17-2018, 08:39 AM
bjmayberry2
Does it have the ability to hook to an automatic?
  #425
Old 03-17-2018, 08:44 AM
chad77's Avatar
chad77
chad77 is offline
What do you mean? An automatic transmission vehicle? It will work on any vehicle really. I believe they made it to adapt to any intake.
  #426
Old 03-17-2018, 08:59 AM
bjmayberry2
I need provisions for the automatics kick down.
  #427
Old 03-17-2018, 09:03 AM
chad77's Avatar
chad77
chad77 is offline
Oh ok. Ya I'm not sure. I thought I seen a video on YouTube where it said it was adaptable but I'm not sure. That's a fitech question
  #428
Old 03-17-2018, 05:02 PM
chad77's Avatar
chad77
chad77 is offline
All installed.
Works really good.
Very little initial programming (set your cubic value, Cam aggressiveness (1-4,4 being aggressive), rpm limit etc. Then the handheld can be disconnected for a cleaner look.
Plugged the old fuel pickup as it has to stay in the tank for the fuel level sender. Which is why the new electric pump is installed where it is. Only flat spot available.
Instead of using a hole saw and making a mess. I did this and used tin snips
  #429
Old 03-17-2018, 05:06 PM
chad77's Avatar
chad77
chad77 is offline
F-1
Ford Truck Parts for Sale
02-08-2018 01:13 PM
mod22
21
02-06-2018 05:29 AM
ultraranger
11-16-2017 03:24 PM
abe
13
07-17-2017 03:48 PM
pbsdaddy
07-16-2017 02:49 PM
Quick Reply: 56' racecar themed F-100
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
