56' racecar themed F-100
  #166
Old 04-25-2016, 08:46 AM
chad77's Avatar
chad77
chad77 is offline
chad77 is gaining momentum as a positive member of FTE.chad77 is gaining momentum as a positive member of FTE.
  #167
Old 04-25-2016, 10:43 AM
CharlieLed's Avatar
CharlieLed
CharlieLed is online now
CharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant future
Pretty bead but it looks like it does not bridge the seam. Looks like you have access to some very nice metal cutting equip...appears to be as nice as any Art Morrison or TCI frame.
  #168
Old 04-25-2016, 12:14 PM
chad77's Avatar
chad77
chad77 is offline
I had my buddy weld it as its his every day job. The pieces when put together have a 'crater' or ledge to fill so it grabs on the edges and not just the surface.
  #169
Old 04-25-2016, 12:42 PM
F1 Mike
F1 Mike is offline
F1 Mike is gaining momentum as a positive member of FTE.
Looks like a TIG weld made adding no filler in which case the ledge would have, should have (?) melted into the vertical piece underneath. I can't see the heat affected zone in the vertical piece from the angle of the photo so it's really hard to tell. Definitely less than ideal configuration for a MIG weld.
  #170
Old 04-29-2016, 05:20 PM
chad77's Avatar
chad77
chad77 is offline
  #171
Old 05-01-2016, 05:20 PM
chad77's Avatar
chad77
chad77 is offline
Four bar link
  #172
Old 05-09-2016, 07:41 PM
chad77's Avatar
chad77
chad77 is offline
  #173
Old 05-10-2016, 07:43 PM
chad77's Avatar
chad77
chad77 is offline
  #174
Old 05-30-2016, 07:52 AM
chad77's Avatar
chad77
chad77 is offline
  #175
Old 05-31-2016, 08:37 PM
Purple55's Avatar
Purple55
Purple55 is offline
Purple55 is gaining momentum as a positive member of FTE.Purple55 is gaining momentum as a positive member of FTE.
Looking great! Lots of work, though. I also did a race car themed chassis on my 55. Can't wait to see yours when its done.
  #176
Old 06-12-2016, 07:33 AM
ford_0004
ford_0004 is offline
ford_0004 is starting off with a positive reputation.
Originally Posted by chad77 View Post
Custom floor mount and column drop...<br/>Lol<br/><br/><br/><br/>Has anyone ever went through the firewall with the column instead of the stock location? Not sure i like the angle of the wheel, even with the tilt.
Look up " Over Staked Ford chopped top at sema 2015 " by bayonecstoms .They did a column relocate to give more interior floor space .
  #177
Old 06-19-2016, 03:52 PM
chad77's Avatar
chad77
chad77 is offline
http://https://youtu.be/2Z3zuwNdxw8
Shifter linkage mock up
  #178
Old 06-19-2016, 03:54 PM
chad77's Avatar
chad77
chad77 is offline
  #179
Old 07-03-2016, 09:06 PM
chad77's Avatar
chad77
chad77 is offline
  #180
Old 07-12-2016, 09:07 PM
chad77's Avatar
chad77
chad77 is offline
Saginaw mounted on trans crossmember and linkages done
Pt cruiser watts link
Mocked up and passed the straight line test.
Quick Reply: 56' racecar themed F-100
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
