Exhaust thru the front Fender, Opinions
you guys make some good points the first being the fumes, second possible discoloration from the exhaust around the fenders, but as far as noise they would be baffled so thats not an issues and with the cam it should sound pretty cool. Here in AZ you can run whatever you want, plenty of rat rods running straight headers etc, no emissions, inspections etc. I do like CharlieLeds set up though. Going to have to think about this a bit more before I cut holes in the fenders, but I do like the look, possibly lower in the fender like the pic above.
You could also go from being the person with the cool old truck up the road to the person with a loud piece of s** up the road. I got a kid next door to me which has a loud truck you can hear it three blocks away. I guess I'm showing my age, seems like when I was younger loud noise didn't bother me but as I've gotten older it really gets on my nerves. Kinda like pulling up to a traffic light and someone pulls up with their bass turned so loud the windows vibrate.
Don't want to be a Kill Joy but
Here are a couple of status that you may want to know about;
28-955. Mufflers; noise and air pollution prevention; emissions control devices; civil penalty; exception
A. A motor vehicle shall be equipped at all times with a muffler that is in good working order and that is in constant operation to prevent excessive or unusual noise.
B. A person shall not use a muffler cutout, bypass or similar device on a motor vehicle on a highway.
C. The engine and power mechanism of a motor vehicle shall be equipped and adjusted to prevent the escape of excessive fumes or smoke.
D. Beginning with motor vehicles and motor vehicle engines of the 1968 model year, motor vehicles and motor vehicle engines shall be equipped with emissions control devices that meet the standards established by the director of environmental quality.
E. A person who violates this section is subject to a civil penalty of at least one hundred dollars.
F. This section does not apply to an electrically powered motor vehicle.
and
28-955.04. Exhaust system; visual inspection; requirements; civil penalty
A. A commercial motor vehicle that operates in this state shall have an exhaust system that is detectable by a visual inspection and that meets all of the following:
1. Is free from a defect that adversely affects sound reduction.
2. Is equipped with either a muffler or other noise dissipative device.
3. Is not equipped with a cutout, bypass or similar device.
B. A person who violates this section is subject to a civil penalty of at least five hundred dollars. If the person shows the court that a muffler has been installed or the existing muffler has been serviced to comply with subsection A, the court may reduce or waive the civil penalty.
and
I believe we all should follow our dreams as too how we want our truck to look, so as far as aesthetics go, if you like it that's all that matters. But when it comes to safety. I will give you my concern. Carbon monoxide is odorless, deadly, can build up slowly and it causes death quickly. And from what I've been told (by my HS auto shop teacher)has no or very little warning signs except maybe skin discoloration (redness)about the time of death. So I agree with what Ax stated in Po#20. Please be careful with things that cant be seen, smelled, or heard. The odor that we associate with exhaust gas is a mix of gasses and the carbon monoxide part of it is odorless. Enjoy your build and enjoy the cruise.
I would like to hear the logic behind a REG that places the tailpipe outlet several feet closer to the cab windows, That sounds like a rule designed for an SUV with a rear window, and being generically applied to pickups.
Received 4,132 Likes
on
I think he means it cannot be in front of the back of cab, and must direct the exhaust to the side and down. Not saying it has to exit right behind the cab. Big van trucks almost always dump down just behind the cab.
#28
#29
#30
That setup looks very aggressive but there are some very serious issues with it...first, if you pull up next to another truck/car you will be blasting them with your exhaust. Second, do you REALLY want to have that much noise so close to your door window when you are cruising down the road?
Here is what I consider to be a better solution, it keeps the noise behind the cab and the exhaust lower to the road...
