What else should I do with Ball Joints?
I am going to have to replace ball joints on my truck.
It also need Hubs.
Going with the Moog Ball joints and MM Supreme hub.
While I am in there. Are there other parts that I should replace?
I am not a mechanic...but pretty good parts changer. Got the write ups and stuff. So just wondering what else I should be looking at to save trouble later if anything?
It also need Hubs.
It also need Hubs.
It also need Hubs.
Your not the only one that had problems with Moog, I only got at most between 40-60k out of the top ball joint (2wd trucks) the bottom ones have held on good.) I woul also recommend to go with Spicer
I have the XRF joints on two trucks and have been there for a good while with no complaints.Just my .02.
This may help you,
Ford Super Duty Ball Joint Replacement Procedure | Superdutypsd.com
This may help you,
bmac4020
03-20-2010 06:18 PM
