Knobs
Old Nov 24, 2015 | 12:48 AM
pyrotvfun's Avatar
pyrotvfun
Im taking apart the dash to find a short and take a look at my gas gauge since its off. Its empty mark is half a tank. But the main real question is I need to take two ***** off, the windshield one off so i can take the cover off for the instrument cluster.
https://goo.gl/photos/tzMrVPRypQ4DbhKq6
A how to video would be best if anyone can make one. I saw that there is one post on here already on this and i tried it and it didnt work or im not looking hard enough
Old Nov 24, 2015 | 07:56 AM
maytag906's Avatar
maytag906
In picture 2, you see 2 small slots on the top of the *****. Stick a small screwdriver or similar in there to release the spring, and pull the **** off.
Old Nov 24, 2015 | 09:05 AM
1986F150six's Avatar
1986F150six
I have used a small allen wrench. Take the short side of the "L" and insert it into the slot and pull hard while also tugging on the ****. On some headlight switches, there is a button on the actual switch [under the dash]. If so equipped, the button can be pressed and the shaft will come out with the **** still intact. This will turn on the headlights, so the battery terminal will need to be disconnected.
Old Nov 24, 2015 | 10:19 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I use a cotter pin puller.
Sometimes you can't just yank out on the tab, you have to pull the tab back against the ****.
Dirtay Don
Jan 3, 2018 08:42 AM
creedua
Mar 12, 2015 04:41 PM
TheMachfather
22
Jan 21, 2004 10:05 AM
ford390gashog
Jan 3, 2004 01:02 AM
Lookinfurfun
1978 - 1996 Big Bronco
Oct 1, 2002 05:22 PM
