dana 44 front end
dana 44 front end
I need a Dana44 front axle with 3.00 gears or so what I found out so far here it is
I can use a 1976 to 1977.5 for my app they have low pinion can get gears but they are in f250
so can I bolt the f150 spindles and hubs to get the brakes I need
the other question how much wider is the f250
thanks for your help
on
Looking to something similar, an f250 dana44 in an f150.
High pinion or low pinion, I suspect the pinion angle is different and might point it wrong for a non-cv driveshaft.
Steering Knuckles outward to swap to 5 bolt pattern. According to Mr N's website, the steering knuckles are thicker in one area where the brake calipers mount to or some other fitment reason. I don't have all the parts to be certain, but doubt you'll have a problem if you swap knuckles outward.
And the F250 Dana 44 is wider. Not sure by how much...
1972RedNeck
01-27-2013 06:56 PM
