SPX, Riffraff, Barder and others turbo wheel review thread
Just waiting now to coat the cac pipes and spider when it comes off. Bunch of RR stuff coming to install it all. EBPV delete, new boots, clamps, orings, etc.
Hey guys cleaned and rebuild the turbo with the SPX wheel today, this turbo is going into my truck in a couple of weeks, but I'll remove my turbo on the weekend and install another SPX wheel I originally was going to install, just to give some feed back on how it worked
For the mean time heres some pics of the clean and painted turbo.
Deleted ebpv
Painted cover and back plate
Deleted ebpv
And last SPX wheel installed
And yes I painted the wrong housing, instead of the e99 I painted the obs one
Deleted ebpv
Deleted ebpv
Well got the SPX wheel on my obs turbo and WOW! WOW! Spools quick and sounds amazing, specially when you let go off the peddle after a wot run
Overal really satisfying experience with the wheel. I used my hot tune at wot and my egt would not go above 1300° (before it would hit 1350 egt ,so -50° with just a wheel good enough for me)
and little smoke to, as for boost don't know yet! got to get a new boost gauge that reads higher than 30lbs
Well worth it I recommend it to all of yall it wont disappoint.
Heres some pics of it installed
I will try to find out how my egts are when I tow my TT just to give you guys an Idea how much of a difference it made.
Used the truck today going up a 8% grade about 5 miles long, my egt on my hot setting only hit 1050egt before I would easily hit 1150 going 60mph.
For what its worth my truck has the following mods
Stage 1 rosewood injectors
T500 hpop
Tw tunes
6.0 intercooler
E99 turbo pedestal and center cartridge with obs T4 exhaust housing
3" to 4" turbo back
Spx wheel
Almost forgot 6637 air filter
T500 hpop
Tw tunes
6.0 intercooler
3" to 4" turbo back
Spx wheel
T500 hpop
Tw tunes
6.0 intercooler
3" to 4" turbo back
Spx wheel
T500 hpop
Tw tunes
6.0 intercooler
3" to 4" turbo back
Spx wheel
Good job. All my parts are now here, just need to find the time to get it done. Doing up pipes as well since I am that far in it.
Yup I just had to, will see how much quicker it will spool once I put the sd turbo in there. But you wont be disappointed, theres definitely feel in the pants power and the turbo sounds aggressive not the average obs wheel sound more like a fighter jet sound, cant explain it but sounds nice, and a plus egt reduction which what I was looking for
