SOUND DEADENING / INSULATION TIME!
The results are in!
So here are the results for the insulation project so far...
Just a note, here is what I have insulated to this point:
*All doors.
*rear floor from behind the front seats to the rear doors.
*rear quarter panel from wheel well back to tail light on passenger side.
So I took the DB readings with an Iphone app.. we all know that they are spastic but I seem to have this one figured out so it reads relatively accurate and consistent. For both tests I laid the phone in the center of the floor where the first bench or rear captains chairs would be, with the mic pointing in the same direction.
TEST 1:
*Rear Interior gutted
*Doors already insulated prior to this test.
*All doors and windows closed.
77 DB @ idle with heater fans on high(testing thermal gains as well)
96 DB Revving to 2k rpm
TEST 2:
*insulation in place on floor, pass rear 1/4
*Vinyl flooring installed
*No rear seats installed(they help cut noise as well)
63 DB @ idle with heater fans on high
73 DB Revving to 2k rpm
So this is a significant change.. so much so that I didn't believe it. So after a road test I now believe! It's bittersweet because now I cannot hear the pipes bark when I hammer on it. So if I want to hear the 7.3 bark I have to roll the window down
Thermal efficiency is much improved, there is a rear heater in the truck and previously it would work well BUT, now I barely have to run it to turn the rear into a sweat box.
I can't wait to do the side panels because they are SOOO hollow sounding, but I need to find a parts van that has my panels first because some of mine were broken when I bought it and my experience is that I will most likely break some as well during dis-assembly.
*All doors.
TEST 1:
TEST 2:
*All doors.
TEST 1:
TEST 2:
*All doors.
TEST 1:
TEST 2:
hail destroyer
09-15-2016 01:17 AM
Dr. Johnson
29
08-19-2016 07:17 PM
WALFORD'S 56
23
09-27-2007 07:11 AM
