Grandpa's 55' F350 restore - Page 2 - Ford Truck Enthusiasts Forums
Old 11-23-2015, 07:22 PM
1952henry's Avatar
1952henry
1952henry is offline
1952henry has a good reputation on FTE.1952henry has a good reputation on FTE.1952henry has a good reputation on FTE.
And another welcome. Good for you for saving a tonner, especially since it's been in your family!
Old 11-24-2015, 09:29 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has a brilliant futureJolly Roger Joe has a brilliant futureJolly Roger Joe has a brilliant futureJolly Roger Joe has a brilliant futureJolly Roger Joe has a brilliant futureJolly Roger Joe has a brilliant futureJolly Roger Joe has a brilliant futureJolly Roger Joe has a brilliant futureJolly Roger Joe has a brilliant futureJolly Roger Joe has a brilliant futureJolly Roger Joe has a brilliant future
Welcome to FTE!
Nice truck and a great story.
Old 11-29-2015, 12:34 AM
Quesera
Quesera is offline
Quesera has a good reputation on FTE.Quesera has a good reputation on FTE.
Welcome! I've been lurking around this forum for a while, reading up, getting inspired, getting informed, and getting a little bit nervous about starting my project. My great-grandfather's 1951 F-1 was driven by my great-grandfather, grandfather and my father. After losing my dad four years ago, I've known that the truck was something I needed to do to feel a little more whole again. I'm looking forward to following your restoration project!
Old 11-29-2015, 07:26 AM
FortyNiner's Avatar
FortyNiner
FortyNiner is online now
FortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud of
So, don't be shy Quesera. Start your own thread and share some pics. We're a friendly bunch of enablers.
Old 12-18-2015, 08:46 AM
df85732's Avatar
df85732
df85732 is offline
df85732 has a great reputation on FTE.df85732 has a great reputation on FTE.df85732 has a great reputation on FTE.df85732 has a great reputation on FTE.df85732 has a great reputation on FTE.df85732 has a great reputation on FTE.
Engine Score!
Not much to report other than I'm ready for Spring already!!! Sorry no progress pictures. But.........while doing a local CL search I found a 239 Y block just like mine. The guy pulled it out of a 55 F100 and had a video of it running before he pulled it. He's going bigger. His loss my gain! So now I'm trying to decide whether to use this engine or still rebuild the one that's in the ole girl. Do any of you know if the high fan mount fan water pump will fit on the EBU (F150) engine. Also not sure if the tranny and drive shaft will match up? It was a deal I couldn't pass up so the shop just got smaller. Hope you all have a Happy Holidays and may your "projects" fill you with joy!
CL purchase
CL purchase
Old 12-18-2015, 11:21 AM
Jafo56's Avatar
Jafo56
Jafo56 is offline
Jafo56 has a very good reputation on FTE.Jafo56 has a very good reputation on FTE.Jafo56 has a very good reputation on FTE.Jafo56 has a very good reputation on FTE.
Congrats on your new project! Great starting point!
Old 12-18-2015, 11:57 AM
Aloha-boy's Avatar
Aloha-boy
Aloha-boy is offline
Aloha-boy has a good reputation on FTE.Aloha-boy has a good reputation on FTE.
Awesome back story to your truck!
Old 12-19-2015, 03:31 AM
hoss73ford
hoss73ford is offline
hoss73ford is starting off with a positive reputation.
One can tell it's the original engine with the high fan water pump. Love to see originals or one that is being built to such.
Old 04-03-2016, 07:06 PM
df85732's Avatar
df85732
df85732 is offline
Express Bed Removal
Finally getting some time and weather to work on my project. Today I started an attempt at getting the bed off the frame. Did not get it totally accomplished and came up with a few questions along the way. This is a 9' express bed. After two hours, grinding, prying, chain sawing, and eating 61 years of dirt I finally got the 8 bolts off that hold the bed to the frame. Now for the questions. Can you tell from the pictures if the heavy duty bumper came on the truck or was it put on after delivery? It is welded to the frame and also welded to the fender and side of the bed. From what I can see I will need to cut these supports to lift the bed up. The other question is about the tail light brackets. They are different and i assume the one has an extra bracket to hold the licence plate? Is that correct? Thanks for your comments.
Bed Bolt
Bed Bolt
Rear Bumper supports.
Left turn signal.
Right turn signal.
Old 04-03-2016, 07:23 PM
abe's Avatar
abe
abe is online now
abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.abe has a spectacular reputation.
Question 1: bumper is not a Ford original. It is after market. It may have been a dealer add on.
Question 2: tail light brackets are Ford originals. It probably came with only the left taillight and the right was added later per state law. They are the same. Look closer and you'll see the license plate bracket is attached to the left side bracket.
Old 04-05-2016, 09:53 PM
df85732's Avatar
df85732
df85732 is offline
Bed Removal Continued
Well I got the Bed pulled off today. For you F100ers I can honestly say that the 9' express bed weighs more, obviously . Since I didn't have any helpers I resorted to using my tractor with a couple of tow straps. It worked well. Now I plan to evaluate the condition of the bed, frame, rear end, etc. Note the added on rear Bumper. I think I will remove it and not put it back. I personally think it will look better without it. Any thoughts?????
Old 04-05-2016, 10:14 PM
abe's Avatar
abe
abe is online now
About the rear bumper.... I would leave it off. You can buy a new stock steel painted black bumper for about $110.
Your bed looks in great shape!
  #28
Old 04-06-2016, 08:24 AM
FortyNiner's Avatar
FortyNiner
I'm with Abe on the bumper, Dave. It was needed as a working truck. Now, not so much.
  #29
Old 04-15-2016, 04:11 AM
Jules The Great
Jules The Great is offline
Jules The Great is gaining momentum as a positive member of FTE.Jules The Great is gaining momentum as a positive member of FTE.
I would bet my life that that bumper was home made or shop made, not a dealer add on or other after market! Maybe your grandfather or father made it?
Also I love your trucks history, I wish I could have inherited mine, instead I bought it off someone whos grandkids did not care to own it...
  #30
Old 04-15-2016, 05:21 AM
1949f1's Avatar
1949f1
1949f1 is offline
1949f1 has a great reputation on FTE.1949f1 has a great reputation on FTE.1949f1 has a great reputation on FTE.1949f1 has a great reputation on FTE.
Welcome and cool story. Good luck on your build
Quick Reply: Grandpa's 55' F350 restore
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
