Ford Changed 6.2L Oil Spec to 5w/30 for MY 2016 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Reload this Page >
6.2L V8 Discuss the 6.2L V8
Old 11-21-2015, 04:01 PM
1medic
1medic is offline
1medic is starting off with a positive reputation.
Anyone else notice the oil spec change to 5w/30 for MY 2016 in the 6.2L? Ford implemented the change in MY 2015 in the Commercial Cutaways. I'm sure the diehard 5w/20 users will have something to say.
Old 11-21-2015, 04:28 PM
ATP Pilot's Avatar
ATP Pilot
ATP Pilot is online now
ATP Pilot is gaining momentum as a positive member of FTE.
so no TSB or anything explaining the difference between years? Should the older 6.2 switch too?
Old 11-21-2015, 06:58 PM
clintbonnie
clintbonnie is offline
clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.
Subscribing... wondering whats going on with the switch. Did Ford Engineering find a problem with 5W20 in 6.2L ?
Old 11-21-2015, 07:34 PM
T diesel's Avatar
T diesel
T diesel is offline
T diesel has a very good reputation on FTE.T diesel has a very good reputation on FTE.T diesel has a very good reputation on FTE.
I'd like to know as well.
Old 11-21-2015, 07:59 PM
don123's Avatar
don123
don123 is offline
don123 is starting off with a positive reputation.
Yes what's different?
Old 11-21-2015, 11:17 PM
FordmanNJ's Avatar
FordmanNJ
FordmanNJ is offline
FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.
5W30 is just a slightly thicker oil that would give some additional protection. It sounds like Ford might be going back to the 10W-40 days. When I was growing up dad would change the oil in the driveway. Every 3000 miles. In the summer months, it was 10W40. In the Winter months it was 10W30. Anything else was sacrilage. This was true into the 2000s. When I had a Explorer it required a 5W30 that was "This cannot be correct" in his book. Now even he uses 5W30 for everything except on vehicle which still gets 10W-XX Now when I worked for a local telecom company, it was 15W40 in everything gas or diesel. You got an oil change once every 6 months.
At work, I just changed the oil in the work van (E250 with a 4.6 V8) with MC syn blend 5W20. However, I would consider using a 5W-30 or due to the wear on the engine and the condition the engine is used in "i.e. towing and delivery vehicle". While performing the oil service, the boss asked me the best realistic practice. I said not like my last company, too long between. Going every 5K is going to increase downtime and create scheduling issues for servicing. I said once every 4 months with a regular oil checks once a week should keep the engine happy with oil. We know we have been burning oil. Now we keep some on hand when it gets checked.
IMO, 5W30 would offer better protection to the engine and should be modified to the climate.
Old 11-22-2015, 01:22 AM
1medic
1medic is offline
My guess is it's not problem related. Ford may specify what oil weight they recommend but as we know owners will run all sorts of weights. I've run 30 and 40 weight full syn's for long OCI's in my previous Triton engines without issue. The OA's I did previously were all unremarkable. I'll be doing long OCI's on my 6.2L and sampling along the way to see how far a full syn can be extended in these newer beasts.
I suggest doing some research on the "bob is the oil guy" forums and educate yourselfs further. Lots of good info.
Old 11-22-2015, 11:35 AM
Squisher's Avatar
Squisher
Squisher is offline
Squisher has a good reputation on FTE.Squisher has a good reputation on FTE.
Interesting. I think many of us though would like to know Fords reasoning for changing the recommended flavour, not read through a whole ton of technical stuff on oils.
Old 11-22-2015, 07:04 PM
Unclemark
Unclemark is offline
Unclemark is starting off with a positive reputation.
Im curious as well
Old 11-22-2015, 07:50 PM
brokenleg
brokenleg is offline
brokenleg has a good reputation on FTE.brokenleg has a good reputation on FTE.brokenleg has a good reputation on FTE.
Interesting.......
Old 11-23-2015, 07:50 AM
Chuck's First Ford
Chuck's First Ford is offline
Chuck's First Ford has a very good reputation on FTE.Chuck's First Ford has a very good reputation on FTE.Chuck's First Ford has a very good reputation on FTE.Chuck's First Ford has a very good reputation on FTE.
I have No idea Why Ford changed.
could be 5w20 is going away...
after millions of miles.. Ford seen something and wanted the change.
wear OR weather/temperature related.
https://answers.yahoo.com/question/i...6091126AAtqEN4
http://www.machinerylubrication.com/Read/518/motor-oils
Old 11-23-2015, 09:29 AM
Krewat's Avatar
Krewat
Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Look at the specs on the 5w30 oil they want. Is it synthetic now, when the previous spec was semi-synth or dino could be used?
My Taurus with the 3.5L Ecoboost takes 5w30 semi-synth, and I use full synth Mobil 1 in it.
I suspect that they are just switching everything over to the 5w30 that my Taurus calls for as a cost-saving measure for factories and dealers.
This is like when I got my V10 - previous year used 5w30, mine said 5w20 - I stuck with 5w30
Old 11-23-2015, 09:49 AM
rvpuller's Avatar
rvpuller
rvpuller is online now
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
It will be interesting to see it their Quick Change lanes stay with 5w-20 or go to the 30 weight, I think I will ask next time they change it for me.
My 2000 V10 said 5w-30 and that's what I stayed with for 13 years even after the service builtin came out.
Denny
Old 11-23-2015, 12:54 PM
EBTDM
EBTDM is offline
EBTDM is starting off with a positive reputation.
I am going to go with this explanation.
Making a slight gas millage difference for the levied requirements.
Old 11-23-2015, 01:57 PM
JIM_C's Avatar
JIM_C
JIM_C is offline
JIM_C is gaining momentum as a positive member of FTE.JIM_C is gaining momentum as a positive member of FTE.
It's probably due to Gullobull Warming ...
Quick Reply: Ford Changed 6.2L Oil Spec to 5w/30 for MY 2016
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
