1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2010 f250 v10 lost all power
Old 11-18-2015, 09:22 PM
ropetexas's Avatar
ropetexas
ropetexas is offline
I have a 2010 F250 with the V10 and 42000 miles. Lost*power*while pulling a trailer. Couldn't get over 30 mph. Tried turning back home and lost all*power*and would barely idle. Fuel filter good air filter good. Code P0300 came up. Towed it back to the house and then couldn't even get it to idle. Wouldn't throttle up past about 2800 rpm. Cleaned MAF sensor and nothing. Somewhere during all that P0174 code came up and misfire cylinder 10. Cleared codes and they haven't come back. Now when trying to crank, it barely turns over, yet battery is good. Opened air filter cover after getting it to start one time and there was some light smoke coming out. Also while barely keeping it running for a little bit, the catalytic converter on the driver side was fire hot and the other side I could grab with my hand. Any help??
Old 11-18-2015, 10:15 PM
5 on a side's Avatar
5 on a side
5 on a side is offline
you might want to look in the V10 section, and read this
https://www.ford-trucks.com/forums/1...0-pinging.html
Old 11-19-2015, 09:46 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
Clogged exhaust?
Old 11-19-2015, 10:26 PM
ropetexas's Avatar
ropetexas
Originally Posted by 99f350sd
Clogged exhaust?
I'm thinking the driver side cat is clogged for sure, but something caused it. There is a recall on the cat y pipe. Don't think that would cause my problems though. I think I'm going to pay the $150 to Ford and let them tell me what's wrong.
Old 11-20-2015, 07:39 AM
Tom's Avatar
Tom
Tom is online now
That may be your smoking gun. Remove your oxygen sensors and see how it runs. If the converters are clogged it should run better because the exhaust will have a path to flow through the oxygen sensor ports.
Old 11-20-2015, 08:30 AM
ropetexas's Avatar
ropetexas
Yeah, I'm going to try that tomorrow when I have some time. Thanks.
Old 11-21-2015, 05:06 PM
ropetexas's Avatar
ropetexas
Pulled upstream O2 sensor on hot cat side and truck cranked with ease and started right up. Still running a little rough so I pulled the other side and she purrs like a kitten. There is a recall on the catalyst y pipe. Question is, does anyone know if the y pipe includes the cat's???
info_napl
Modular V10 (6.8l)
16
05-07-2010 04:56 PM
george2001
05-23-2009 02:20 PM
goat6t7
Modular V10 (6.8l)
15
09-07-2006 07:32 AM
captainsstable
Modular V10 (6.8l)
01-26-2005 11:57 AM
Daren12
03-29-2003 09:48 PM
Quick Reply: 2010 f250 v10 lost all power
