help!! 1978 F-600 4x4
Hello, I am new to forum . Recently brought her home, first step is brake sys. overhaul. Rockwell axles & Warn lock-out hubs. I removed the eight allen head screws that retained the locking hub cover/ in-out ****, then the snap ring & washer, that allowed access to the snap ring that was on end of axle shaft, removed it. The assembly will now slide outward on the splines of the shaft to about 3/16" then stop. Could the shaft outboard of the snapring groove be mushroomed or the splines boogered up?? How rough with it can I get? I figure parts are hard to find? thanks in advance !
1st off it is a Rockwell axle not a common D44 or D60 that most us deal with. Have you asked this question here? Large Truck - Ford Truck Enthusiasts Forums
Or ask this guy for sure, he has Rockwell's under his Ford truck. And I know Alan has been into it and over hauled them before, so for sure he will know.
Ford Truck Enthusiasts Forums - View Profile: earthquake68
On our little stuff you have to remove the wheel/tire, caliper, hub/rotor, caliper mount plate and spindle to get an axle to pull out.
There is a youtube video rebuilding these..parts 1 and 2
I have a 79 f600 4 x 4 Fire Engine
Mine slides right off.. I suspect munged part..inspect carefully
Also suspect warn hubs..why were they put on and when
here you go
notme
rct2000
02-03-2015 08:13 PM
HiZ
04-14-2014 07:15 PM
Skydmark1
03-22-2009 02:47 PM
alta825
09-20-2007 07:10 AM
pcorona
07-16-2003 08:11 PM
