Hot Rod Flatz paint
Old 11-11-2015, 12:52 PM
ETOWN55's Avatar
ETOWN55
ETOWN55 is offline
Hot Rod Flatz paint
Has anyone used any of their paint products. I'm interested in their paint. I want to paint my truck a red like in the picture.
Old 11-11-2015, 01:27 PM
gerrymoe's Avatar
gerrymoe
gerrymoe is offline
I have, the 33 you see below is Hot Rod Flatz Gunsmoke. Have had it on for approx. 5 years now and no UV effects yet. I wash it with water and soap, does not hold finger prints like the primers. Make sure you get the product to air mix proper while spraying, don't keep pulling the trigger while spraying, constant as much as possible, lays down real nice and don't spray if hotter that 80 outside if not in a controlled paint booth
Old 11-11-2015, 01:32 PM
fatfenders's Avatar
fatfenders
fatfenders is offline
Have some friends that have used it. I have tried some other brand flat paints. I really like the look. It looks nice as long as you treat it like a garage queen. Any flat finish is high maintenance. I expected the opposite result when I did it on a car. It looks great at first but then it gets dirty and water spotted super easy and it's real tough to maintain a uniform look. Ever see a factory matte black Harley? Next time you do, ask the owner what he has to do to keep it looking nice. You would think there is some product out there you could apply like you would a wax.
I got a similar affect by using cheap acrylic gloss enamel and letting the sun eat it up a few years.
Old 11-11-2015, 02:07 PM
ETOWN55's Avatar
ETOWN55
ETOWN55 is offline
It looks like the 1707 candy apple red Hot Rod Flatz. In the picture I posted.
Old 11-11-2015, 02:14 PM
fatfenders's Avatar
fatfenders
Originally Posted by gerrymoe
... Make sure you get the product to air mix proper while spraying, don't keep pulling the trigger while spraying, constant as much as possible...
Can you explain that part a little better? I'd like to have the flat option but just haven't seen it last. Perhaps the application is the key. Sounds like you are saying to spray it dry.
It's gotta be better than primer. Primer is not designed to withstand UV. It's bad news for a number of reasons. Stuff rusts around here with most primers used as a topcoat. Epoxy primer will hang on awhile
Old 11-11-2015, 02:31 PM
ETOWN55's Avatar
ETOWN55
ETOWN55 is offline
I think what gerrymoe means is you have to have a steady spray.
Old 11-11-2015, 04:44 PM
gerrymoe's Avatar
gerrymoe
gerrymoe is offline
Exactly, you want to keep it wet, with a good overlap and keep the paint gun an equal distance from the surface constantly
Old 11-11-2015, 05:09 PM
fatfenders's Avatar
fatfenders
Thanks, sounds like the same rules as properly applying any other paint. Please share the results if you try it Etown. Not for everyone but I think it looks pretty good.
Old 11-11-2015, 05:47 PM
ETOWN55's Avatar
ETOWN55
ETOWN55 is offline
Its going to be awhile but I will.
Old 11-17-2015, 05:17 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
There are now several cleaning products for flat paint.
Old 09-13-2016, 12:50 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
I just painted my first panel with Flatz Hot Rod Red. Now I have painted cars before but I'm not an expert like some on this forum, but I found this paint very easy to lay down smoothly without runs or orange peel. I'm sure that it also has to do with my first use of an HVLP gun. I used suction feed guns before.
Two coats on front panel only
Old 09-13-2016, 06:04 PM
Luckylou's Avatar
Luckylou
Luckylou is offline
I have used flatz paint and it's real easy to work with flows nice washes good to
CamoLaw
Appearance & Dress-Up
10-31-2012 05:22 PM
clindahl
Paint & Bodywork
08-09-2011 10:11 AM
77red4x4
Paint & Bodywork
100
11-01-2007 11:47 AM
imlowr2
25
05-01-2007 08:25 AM
f-4x4
Paint & Bodywork
13
08-30-2005 01:04 AM
Quick Reply: Hot Rod Flatz paint
