Possible Causes of Water in Oil 5.0
I'm contemplating pulling the heads. It just seems like a great deal of work (not to mention possible broken bolts) to tear it halfway down. I've got a motor that I'm working on to replace it. I also have very little time to work on it.
Is the oil gray? Or is it black? If it's not gray, you do not have very much water in there. What you are seeing on the dipstick has to be condensation, if the water level was that high, your oil would be foaming and pushing out the dipstick hole.
You could pull your spark plugs and see if one has white specks on it - that would mean it's been burning water.
Your right though, pulling plugs is probably the next thing I should do.
Even 15 minutes is not enough to clear the condensation out the PCV.
When it runs less than 1/2 hour and sits all day just to get cold again it is going to show condensation.
If the oil is not a milkshake when you shut it off it's likely fine.
You should drive the truck more.
upper radiator hose or where it bolts to the intake
#28
Sounds about right, thermostat housing usually the cause, and I will say its a mother to get at. i think the last time I had to play with mine I took the a/c/power-steering bracket clean off so i could get to the bolts easily.
#29
I think its the timing chain cover. It seems like a design flaw that the water pump bolts hold the timing cover tight. Every time the water pump is removed or replaced the timing cover gasket is slightly relieved of tension. So far every 302 I have owned has now had this issue. Also the water pump bolts do not stay snug.
#30
I drained the oil and it really didn't look abnormal. I did notice that the oil filter seemed to hold a lot of old oil when pouring it in the catch pan. It seemed very strange that almost none came out. This might explain why the oil pressure gauge was taking several seconds after start up to move. Its behaving normally now. Anyone ever had a bad FL1A before?
