2004 f350 driveline removal
Hello,
I'm attempting to remove my driveline to lube my slip joint. I have a 04 f350 crewcab longbed and all the guides I have seen are a little bit different than mine. I have removed the four bolts at the rear axle and removed the band on the slip joint cover but I can't seem to get the driveline to fall.
I have beat on it and can't get it to budge. It seems like the carrier bearing is holding everything up. Should I remove the 4 bolts closest to the transfer case?
NOT GOOD. The driveling is balanced and a hard hit like that could cause issues. You shouldn't have to beat it with anything, but if you do a brass hammer and strikes on the YOKES is advised.
