Cant keep her running
At the very least you should get the System Pass code of 11. No codes could caused by dirty/corroded contacts on the test port or you have a bad computer.
Time to pull it out and inspect. It's behind the driver side kick panel and comes out from the cab side after disconnecting the connector on the firewall side.
It's not that bad...
Plenty of recent threads from folks like yourself having the same issue. Search on keyword "capacitor"
A photo from a recent thread:
upper left, look closely at the round blue cylinder (capacitor) that sprung a leak and swelled up.
From this thread: https://www.ford-trucks.com/forums/1...-no-start.html
There are dozens more....
Ok got everything cleaned and checked out computer was good, took a little work cleaning connections but simple enough. Got some codes while running koeo.
41 lean fuel
84 egr
95 fuel pump
95
95
96 fuel pump shows no power
118 ect sensor
So now my question is it possible to run a regular electric fuel pump with a separate regulator?
41 lean fuel
84 egr
95 fuel pump
95
95
118 ect sensor
kgrasso
10-25-2015 10:39 PM
f350 4x4 460 5 speed
08-25-2013 09:33 PM
jermill_08
03-16-2009 05:34 AM
