97 7.3 motor build PICSS!!!
#31
You don't want the degas bottle since your cooling system doesn't use one. If Rod's deal falls through, a generic coolant overflow bottle will work, since your pressure cap / fill point is on the radiator. Otherwise, look for an overflow + washer bottles from a '92-'94 IDI. Shipping from MN to TX shouldn't be bad, however, given that the parts are pretty light.
The '97 engine / '94.5 cooling system explains the, er..., creatively customized upper rad hose. Might want to look for a more appropriate hose, as that one looks just a wee bit leak-prone.
Wow, the previous owner sure had a knack for hacking perfectly good (and remarkably easy to maintain) systems on the truck.
#32
I looked tonite, I have both the overflow and the washer tank. I wonder if there the same as a gas motor?? Might help your search.
I'll look into what shipping would be tomorrow.
I think the upper rad hose is still available but you have to find one for a 94.5 PSD. Or I think a 92-94 IDI motor.
#33
Kevin
#35
#36
#37
Cody Phillips
08-09-2019 05:56 AM
91dirtydiesel
307
09-13-2013 06:40 PM
BlueOvalDismantlers
48
07-15-2012 05:40 PM
