Debating doing a 5.8 turbo build
I have a 1997 F250 5.8, so its Speed Density and OBDI. Unfortunately from what I've been reading with both of these it would be harder to bring the truck to mix fuel and air because its SD and not MAF. But, I've also been reading you could purchase a Moates Quarter Horse and tune it so it'll all work nicely.
Been adding a parts list together of what I will need and was wondering if anyone with any experience of knowledge could add to what I may need.
99-03 Powerstroke Turbo (Reason behind is for waste gate)
Moates Quarterhorse Chip
Tuning Software
Boost Gauge
Fuel Pressure Regulator
36lb Injectors
Check Valves to MAP sensor so MAP Sensor wont see boost
Piping
Fuel Pumps
Wideband O2 Sensor
Trucks internals are all stock so not looking to be making high boost only around 6-8PSI until I go through it all and get some better internals to push it past that safely because this is a daily driver.
Any help and other information would be appreciated
Thanks, Mike
Tuning Software
Boost Gauge
36lb Injectors
Piping
Fuel Pumps
Wideband O2 Sensor
Thanks, Mike
From my own research and a little bit of armchair racing you can put globs of boost on a stock 351W just fine and given that you have the heads, intake, exhaust, and cam for it as well as a good tune for a setup it has been proven on a dyno by hot rod mag if I am not mistaken that a stock 351W in good shape will make a crap-load of power, your biggest obstical is a good tuning software and either a way to tune it yourself or someone who knows how to do it. I don't rember numbers and I really should dig this articular back up but it was really cool to see how well the stock stuff held up in the end.
Shadow might be referring to this article
How to Push a Junkyard 351 Windsor Past 1,000 HP! - Big-Bang 351W
Held up to 20+PSI and 1,000+HP before failure due to their own fault. I'm so not much worried about getting everything to fit, but as said getting tuning down. This is my daily driver so I don't want to end up getting 5MPG with this thing running crazy rich and just dying out. But, from what Ive been reading on the Moates Quarter Horse I my self could tune it, bring it to get tuned on a Dyno, or spend $100 extra for a custom tune to be done, for all Im doing to it.
Not hard if you use an aftermarket computer setup. A fellow years ago on turboforums used a Holley commander system I believe to run his SD chev setup. Google turbo grenade I think and you should find it. LOTS of reading but well worth it. He was well over 700 HP on literally the worst SBC heads ever made... Ever. And a generic comp cam that just about all hot rodders start with for Chevys lol. Just to see if it could be done. Your best bet is to ready a lot before adding boost.
Edit here's the link lots of good info on timing and fueling
http://www.theturboforums.com/thread...part-2-to-come
94_f150_shortTX
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
03-28-2005 08:00 PM
