Flames out my exhaust manifold
Hi, I just did head gaskets, timing chain, and new distributor on my 5.0 302. Just started it up and there is flames coming out the exhaust manifold.
Is it because the distributor is a tooth off or do I have a different problem? Any suggestions helps. Thanks!
I had a similar issue I don't know what caused it but I removed the smog pump and it quit mostly
In your case I think if it's just the manifolds with no pipes it could be normal if not it seems if the timing gears are off it could have the exhaust valves open at the wrong time
OP you have a timing issue. Re-check your timing. Have you checked it with a light?
I haven't put the light on it yet. I was a little afraid to run it. Whith flames. I don't want to ruin valves.
Glens67
12-10-2016 04:24 PM
tetraruby
03-27-2001 08:40 PM
