I'm doing it - adding the PTC Supp heater to a non-PTC truck!!!
#31
So I went to a buddy's place and he let me tear into his truck (he has the PTC). As it turns out, the connector is on the actual plenum/evaporator harness, which is part 19D605. So looks like I just need to order that harness as well - should be cheap. When I spoke to Ford parts person, she told me only one part number showed up for that, which is clearly not correct. Anyway, off to the dealer tomorrow for one more harness. On the dash harness side, there are 12 wires and only 9 on the plenum side so the extra wires in the plenum harness also look like they will have a home on the controls side. Wish me luck!
#32
#33
#34
So my main issue right now is that I cannot find multiple part numbers for 19D605. All I can find is 19D605-A. Even the dealer said there is only one part number. But clearly the one in my truck does not have the connector for the PTC heater and my buddy's does.
My harness.
My buddy's harness.
My harness.
My buddy's harness.
#35
#36
Ford Changed their harness construction to create harness with more connectors on it so they would stock only one harness instead of multiple harness for similar applications such as you are experiencing.
From Ford Parts website.
Service Wire Harness May Contain Extra Connectors. Consult TSB 06-17-8 For Service Procedures
Think the harness you need could be either depending on when your truck was built
Location #20 - BC3Z-19D605-A WIRE HARNESS W/DUAL ZONE AC, TO 1/18/12 $71.83 $47.41
Location #20 - CC3Z-19D605-A WIRE HARNESS W/DUAL ZONE AC, FROM 1/19/12 $35.08 $23.16
http://parts.autonationfordwhitebear...omponents-scat
Same harness is shown for use on heaters w/o ac also.
#37
I have a 2016 F-250 XLT 6.7L CCSB 4x4 truck equipped with PTC. I just HvBOMed my VIN and came up with CC3Z-19D605-A as the correct part number for my truck if this helps. I am very curious as to why my truck would use a 2012 model year prefix for the part number as opposed to a 2015 model year prefix (since this is when PTC became an option as far as I know).
#39
EVAPORATOR & HEATER COMPONENTS for 2012 Ford F-350 Super Duty
#40
#41
The RapidHeat supplemental cab heater has been available since the introduction of the 2008 Super Duty. I learned about it in the brochure and owner's guide for my '08 which didn't have it. Which prompted me to find a truck that had it when I bought my '11.
#42
#43
New harness arrived. Has the extra connector and it looks like the rest of the wiring matches up except the main connector has 12 wires as opposed to 9 on the other one but there are 12 on the truck side so looks like it all matches up now. So hardware looks good. Only question remaining will be the programming. I guess we will know soon enough....
10 connectors!!!
10 connectors!!!
