Front hvac doesn't work when temps near freezing
I'm trying to track down a problem I'm having with my truck and I can't seem to find anything online.
On my 02 7.3 4wd excursion the front hvac doesn't seem to do anything when the temps are near or below freezing. But once the truck gets near operating temps everything works as advertised. Can anyone point me in the right direction?
I assume one of the doors is not opening. There are some vacuum actuators in there and if they aren't getting enough vacuum until the engine gets to operating temp that would be the issue. Is it a problem with a leak? Vacuum pump? or one of the actuators I don't know. This is the only thing I can think of.
A cold engine won't have hot air to move until motor warms up.
A few more details on the issue would be helpful.
Does air blow out vents when vent is selected?
Do you feel air along with hearing fan motor?
Does air blow out defrost when that mode is selected etc.
Do you have esof, 4x4 auto hubs? If so are they working ok?
Does air switch from vent or floor to defrost when selector is not in defrost mode?
Have you put a non oem or non international thermostat in it?
wmbster
07-22-2013 08:45 PM
wmbster
07-22-2013 12:08 PM
soggybottom
06-07-2011 12:47 PM
