Fuel Leaking during fill up
Last week while filling my tank, I noticed a pool of gas forming under my tank. During a brief inspection under the left rear wheel well, it appears that the fuel is leaking down the drivers side of the gas tank from the spot where the tank meets up with the fuel filler pipe.
During this particular fill up, I had the pump automatically stop twice in the beginning before it finally filled up the tank. Yesterday I tried filling up again...the pump didn't automatically stop and there was no leaking.
Talked to the local Ford shop and they want $120 just to diagnose the problem.
Any thoughts on what could be the issue?
2005 F250 CC Lariat V10 w/112K miles
I had the retaining ring (the screw-on ring that looks like a mason jar lid) snap and the entire "fuel delivery module" including the float, pump, and hoses was just sitting on top of the tank.
But that doesn't sound like your problem
My filler neck was also very corroded and I resorted to sand-blasting and painting it while I had the tank out.
Could be a bunch of things, actually, keep an eye on it when you fill it and see if you can tell where it's coming from.
Took it to a local shop and they didn't see any issues...also, the Scangauge isn't pushing any codes. Apparently whatever is happening it's not immediately apparent when looking at it. I'll just watch it for now and if it continues to occur I'll just have to bite the bullet and pay the $120 for the official ford diagnostic.
silverorange
04-25-2017 08:45 PM
LK
1999 to 2016 Super Duty
01-03-2004 02:46 PM
