Wax and Grease Remover Removes Paint
I am trying to get my '79 E-150 ready for a new paint job. One of the things I did was take out the 2 leaky sunroofs and weld the original panels back in place. There are a few small dings that need body filler.
Before I sand any paint down to bare metal I first clean the area with Duplicolor Wax and Grease Remover. The stuff seems to dissolve paint as I am finding quite a bit of paint on the paper towels when I apply it.
I'm wondering if it is safe to clean the bondo with this stuff before I spray it with 2-part epoxy primer?
What is the condition of the paint? Is it original? If you still have original paint or a repaint that has started to fade and oxidize, I would expect any solvent to take off some paint, just as buffing out the finish would also produce some paint residue on the pad. I'm not a fan of Duplicolor products so I haven't tried this version of W&G remover personally, but absent those characteristics on the paint, I would then lean toward too strong of a solvent in their formulation.
It's the original 36 year old enamel paint. I haven't waxed it in a few years since I was going to do work on it and get it painted so it's tired but not badly oxidized.
I have never used wax & grease remover before so I don't know how normal it is to get paint on the rag. It just seems like it is more than what I expected. It must have a lot of acetone in it.
I think it might be worth trying a different brand.
norvillebob
02-03-2010 01:00 PM
