LETS SEE YOUR 67 TO 72 PICK UP - Page 69 - Ford Truck Enthusiasts Forums
Old 04-02-2018, 06:38 PM
lakequ's Avatar
lakequ
lakequ is offline
lakequ is gaining momentum as a positive member of FTE.
Originally Posted by dkj313 View Post
That's awesome that's a truck. Interested in that radio if you ever decide to let it go... let me know thanks
where are you located at? i am parting the truck out but i do not ship parts
  #1022
Old 04-02-2018, 06:42 PM
dkj313
dkj313 is offline
dkj313 is starting off with a positive reputation.
Rochester, N.Y. sure wish you did
  #1023
Old 06-02-2018, 09:06 AM
Geoff Inscho
Geoff Inscho is offline
Geoff Inscho is starting off with a positive reputation.
Originally Posted by JumpinJim View Post
Baja,
Those are control cables for the Warn winch. There is nothing fancy about my hood release I would guess that it is just like yours- pull the lever under the front of the hood and lift it open.
And that is my parking brake lever on the left side of the steering column- I looked everywhere for another like mine and never found one. I am missing some kind of a **** or something on the end, I never saw it, it was missing when I acquired this pickup years ago. Have you ever seen one like this?
I looked all over the internet; it has this part number C7TA-2A711-A.
Jim
JumpinJim
I would love some info on your lift and tire size/rim specs. Its a drop dead gorgeous truck! Maybe even some more photos 😁
thanks jeff
  #1024
Old 06-03-2018, 11:00 AM
JumpinJim's Avatar
JumpinJim
JumpinJim is offline
JumpinJim is starting off with a positive reputation.
Originally Posted by Geoff Inscho View Post
JumpinJim
thanks jeff
Jeff,
Glad you like my beat-up old pick-up- kidding aside, I'm happy you like my truck. I will be replacing my old Gateway 38" 10.50x16's that have been on my truck for a very long 40 years!
I have them mounted on the original 16" split rims. I bought these new from Dick Cypek and they no longer carry them but Summit sells them today under the name; Coker Tire. Mine have gotten very hard
and out of round. I am going to a set of older Ford one piece 16x6" rims with a little bit shorter tire, 900x16 also available from Summit.
My truck has all original suspension, I did have my springs re-arched a long time ago and I have an AirLift air spring between my front springs and the frame.
My latest upgrade to my truck is the addition of a 427 side oiler, I have had this NOS block for quite a few years and last year decided that "I think I'll put that in my pick-up" so out came the 390.
A year ago, I shipped the block, 428 crank and Lamans rods to Barry Robotnick at Survival Motorsports and had him assemble the short block. I bought a set of his Survival cylinder heads and had him install the roller cam.
I haven't driven but a couple of times since I have been busy trying to get my Holley carb, off of my 390, to work with this new engine. I am using an Innovate hand-held Air/Fuel gauge for tuning.
Jim
  #1025
Old 06-12-2018, 06:45 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.
Jeff,
Jim
I am guessing that is a list number 4779 double pumper 750. Which has one full vacuum and one venture vacuum port for the Dizzy. Is that aftermarket Dizzy curved for full or timed vacuum going to the vacuum advance? You should get the timing and the Dizzy's curve right before tweaking the last bit of power out of the jets choice. If it is a 4779 they came with 71's in the front and 80's in the back. Which sounds good to me depending on your altitude, compression ratio, cam, exhaust system, A/T or M/T, quality of gasoline used, etc.
  #1026
Old 06-13-2018, 05:56 PM
bajafishnut's Avatar
bajafishnut
bajafishnut is offline
bajafishnut is a splendid one to beholdbajafishnut is a splendid one to beholdbajafishnut is a splendid one to beholdbajafishnut is a splendid one to beholdbajafishnut is a splendid one to beholdbajafishnut is a splendid one to beholdbajafishnut is a splendid one to beholdbajafishnut is a splendid one to behold
Very NICE with 5***** on the engine... clean install and clean routing of wiring, hoses, and lines... Love the entire look... especially the full engine compartment...
Baja
  #1027
Old 06-14-2018, 12:20 AM
68AZ
68AZ is offline
68AZ is starting off with a positive reputation.
My current starting point.
  #1028
Old 06-14-2018, 06:09 AM
Yellowfordredhood's Avatar
Yellowfordredhood
Yellowfordredhood is offline
Yellowfordredhood is starting off with a positive reputation.
My bog truck
  #1029
Old 06-14-2018, 06:11 AM
Yellowfordredhood
Gettin dirty
  #1030
Old 06-14-2018, 08:17 AM
keatoma2
keatoma2 is offline
keatoma2 is starting off with a positive reputation.
72 Hiboy 4x4
My latest project. 72 Hiboy 4x4. It's a fairly solid truck.
  #1031
Old 06-14-2018, 08:39 PM
fordbuddy79
fordbuddy79 is online now
fordbuddy79 is gaining momentum as a positive member of FTE.fordbuddy79 is gaining momentum as a positive member of FTE.
All awesome rigs.Here's mine.Not quite a pick up,but hope it's ok...
  #1032
Old 06-14-2018, 08:53 PM
whiskey runner's Avatar
whiskey runner
whiskey runner is online now
whiskey runner has a good reputation on FTE.whiskey runner has a good reputation on FTE.whiskey runner has a good reputation on FTE.
love seeing the old fords work... pretty has its place.. but that look of getting the job done is better in my opinion..
  #1033
Old 06-16-2018, 02:32 AM
SoCal69's Avatar
SoCal69
SoCal69 is offline
SoCal69 is starting off with a positive reputation.
69 250 CS 390 C6
Man these are some sharp rides I just spent some time doing a over my Buget build it took long I had issues still not done still broke but Everytime I drive it I think it was worth it ....specs 69 CS
Riding on squares 1971 date coded bias plys .....
rebuilt 390 & C/6 500 cfm Holly 2bbl. Comp 265 dual energy cam Flexilite Black magic elec fan soon to put on Patriot headers , basics new brakes ,susp ,tires , u joints etc etc
  #1034
Old 06-18-2018, 09:55 PM
fordbuddy79
Plenty more,
  #1035
Old Yesterday, 01:14 AM
whiskey runner
thats what i am talking about...
Quick Reply: LETS SEE YOUR 67 TO 72 PICK UP
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
