Best year for an f250? Also, gas or diesel?
I am in the process of doing my research to buy my first truck and am pretty set on getting an f250. So far, I have really liked the 1997 model. So i was wondering.. Does anyone have any bad experiences with a certain year? Or what year has the best so far, in your opinion?
Also, I am debating between a gas or diesel engine. I am leaning more towards diesel, because I tow and have heard about better fuel efficiency, but I am still learning about trucks and would like some input on cost, reliability, upkeep, etc.
There is a lot of good info to glean on changes over the years here: https://en.wikipedia.org/wiki/Ford_Super_Duty
I personally like my 2005 more than the previous years I had (almost everything is heavier duty), and for my current purposes the 3 valve gas V10 is preferred over the diesel 7.3 I had (though I loved that engine too).
First decide if you need/want a diesel or gas. Diesel will come at a premium both in price and maintenance. They also don't like not to work, so determine if you have enough work for the diesel to do or not.
Once you decide that, you're budget will lead you to specific model years. Then do your research. Generally, the trucks get more capable in the later model years. That's not to say the older ones aren't great trucks too. Good luck.
I'm enjoying my new to me '13 F250 6.2. Mileage sucks thanks to big (but sexy) 33's, (12 mpg roughly) but it's a dirt simple (by comparison) gas motor. I love it.
Go V10 or Diesel for the years of truck you seem to be (edit, not be) looking for and which ever you choose will be better by far then a 5.4 V8..... You gain nothing (even MPG's).
How you use the truck will greatly affect the engine that will be best for you V10 vs Diesel.
Last edited by twigsV10; 11-01-2015 at 09:41 PM. Reason: Miss read the original post. And added (not be)
stay away from the 5.4 at all cost.
But if you are under 10k towing and its weekend warrior and spotty Id stay away from 3/4 tons and get into a half ton. A 1/2 ton built in the last 4-5 years is more than capable to haul that 6k boat around and youll save more money.
The half tons of today are more capable than the 3/4ton gassers of the late 90s and early 2000s.
Can't tow up 18% grade hill at 150 mph probably. I have 3v 5.4 in my 2007 half ton and I thoroughly enjoy it. A very well designed engine with more than enough hp and torque to do anything thats needed.
Same here. My 2v has served me quite well and has spent 90% of it's life with trailers between 6-12k lbs hooked to it. Compared to my obs 7.3 I would take my 5.4 any day of the week.
